Question about Toshiba 43H70 43" Rear Projection Television
Toshiba 48" Projection Model # TP48D51
Have an issue with the screen sucking in at all sides like this  ) (
  • 4,402 Answers
Re: Toshiba 48" Projection Model # TP48D51
Posted on Dec 05, 2007
You lost one of the deflection amps, or have a blown fuse,or an open 2.7 ohm fues resistor on deflection board or possibly all three.Deflection amp module is a stk 392-020 the fuses are marked F702 and F701 for the +32 and _32 volt supplies.
Check all 2.7 ohm resistors R713,720,725,732,739,744 (6 total)
You may also have lost the PA0036 QJ04 IC. This provides the signal called V-wing pin 11 and should be +4.2v to -4.2v in amplitude.This will cause the red and blue to fold over. But the most likely culprit is IC amp, fuse resistors and power fuses
Posted on Feb 04, 2008
0 characters
3 Points
It may not be available due to the age of the set; If Toshiba does not have it there are some sellers on the internet: I would Google the model number with "screen" etc and see if still available or notTP55G60 was a well made model with a good picture and very few issues---you will not get this length of life out of the Plasma or LCD sets being sold now.
Dec 06, 2012 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 56hm66 dark screen
I seem to remember this issue in their sets, might want to spend some time with the model number and search "problems" as I have seen this in one of these before---several thousand sets ago.
Apr 08, 2012 | Toshiba 56HM66 56" Projection HDTV
Toshiba tp48d51 projection tv is making a clicking sound. how do I fix it. It begins clicking as soon as it's turned on. The red needs adjusting and I can't seem to get it right. How do I adjust...
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps in solving the problem, also take caution, because it contains high voltage
May 12, 2011 | Toshiba Projection Televisions
Blue swoosh on screen
Install a convergence repair kit that should solve the issue. You can get the repair kit for your model from
Jan 08, 2010 | Sony KP-48V80 48" Rear Projection...
48 inch toshiba with color alingment problem
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Projection Televisions
Toshiba tp48d51
You need to simply adjust the RED< BLUE & Green guns.
Its in the owners manual.
Nov 10, 2008 | Toshiba 43H70 43" Rear Projection...
Toshiba Model #43H71
go to service mans menu and try horiz width adj..
Sep 22, 2008 | Toshiba 43H71 43" Rear Projection...
Need replacement screen for Mits. WS-48511
The other site i am associated with has used screens for mitsubishi you just have to post the measurements of your screen top to bottom and side to side dont include the frame size as we allow 1/4 inch for fitting in the frame just need the size of the screen to the frame edge.
Mar 31, 2008 | Mitsubishi WS48511 48" Rear Projection...
Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Dec 23, 2007 | Toshiba 57H81 57" Rear Projection...
Screen sucking in
We had that problem, it's a part that has gone defective, we paid about $150 to have someone come out and fix it from Best Buy
Oct 20, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
1,716 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
