Question about Whirlpool Dryers
Dryer won't start after I push the Start button
I turn the Cycle knob to select my Cycle but when I go to push Start button the dryer won't start. You can hear the timer clicking after selecting my Cycle but it just doesn't start. What could be the problem?
    Scholar:
  • 85 Answers
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
105I have a samsung dryer dv409AER/XAA. Currently, I turn the power on and select a cycle and push the start button. When I push the start button - nothing happens. This occurs for any cycle. There is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
My Kenmore 600 series dryer won't start when I push the start knob...I can hear a hum when the knob is pushed in but it won't start. Any suggestions?
heatman101
'lll
Aug 17, 2011 | Dryers
When I push the "push to start" button (knob) on
heatman101
Mar 14, 2011 | Kenmore Dryers
After choosing dryer cycle by turning the selection knob, I try to start cycle by pressing big Start button. It beeps several fast beeps. Also the drum light just stopped coming on.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 20, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Oct 15, 2008 | Whirlpool Dryers
Open Questions:
Dryers Logo
253 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
