Question about Maytag MSD2758GEW
Right door will not stay closed
Right door will not stay open when it is in the half open position nor will it close by itself and stay closed and some times when you close left door right door will pop open the right door would always stay open when it was half open before
Put vaseline on door seals
Posted on May 26, 2009
My son disengaged the latch while the door was open. Then he manually closed then opened the door. When I got home the door was half open and not latched. the trolley on the track was approx 3ft away
If the track is a screw thread, then just latch the door anywhere along the track, and it will realign itself.
If the track is a chain-drive... then push door up until it clicks into latch.
Gene
Oct 09, 2014 | liftmaster Chamberlain Garage Door Opener...
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
2003 ford explorer driver side door opens and closes by itself and interior lights stay on while driving
The opening and closing by itself is either the door being out of alignment or the Door pin being worn and in need of replacement. As far as the interior lights staying on, look for the brightness control for the dashboard lights. If that is turned all the way to the brightest setting there is a position just past that which turns the interior lights on continuous. Make sure it is not in that position. If it is not in that position and the lights are staying on with all doors closed, to include the rears, and you have checked the switch on the dome light itself to make sure it isn't set to ON, then the problem is a switch in one of the door jams being grounded or a wire was tapped into the power circuit for the dome light that has grounded. This happens when the LoJack installer or Alarm installer makes the mistake of tapping the light circuit for power.
Sep 30, 2011 | 2003 Ford Explorer
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
Liftmaster 1/2 - Will not close
What usually happens is a sensor gets bumped so that they no longer are pointed at one another. They must be for the light on the second sensor to come on. Tweak them and see if you can get the light to come on. If you can't you either have bad wiring going to that sensor or the sensor itself has quit working.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Maytag MSD2758GEW Logo
597 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
