Question about Toshiba 43H70 43" Rear Projection Television
Screen sucking in
The screen is sucking in at all sides, top and bottom like this ) (  , I tried everything. My son said unplug it and try that. I did and it fixed it, but for how long? And why is it doing that? Whats the reason for it. Please email me back and let me know what to do. We have owned this TV for 13yrs and the only other problem we have had is it seemed to have had a cyclone effect a couple of years after we got it, had it fixed and no problems since.
Re: screen sucking in
We had that problem, it's a part that has gone defective, we paid about $150 to have someone come out and fix it from Best Buy
Posted on Nov 17, 2007
0 characters
3 Points
Green is warped
replace both convergence ics.they are on the
right side on heat sinks.stk392-110 is the
Jul 17, 2009 | Hitachi 46F500 46" Rear Projection...
You can remove the screen by removing the screws around the perimter of the screen, from the rear on the top and sides, and from the front on the bottom.
Here is a PDF with the instructions.
Hope that helps!  Good luck!
Jan 24, 2009 | Samsung HLN5065W 50" Rear Projection...
My plasma screen has dimmed
i have been fighting a dark screen almos impossible to see dark scenes
i found this from another person
the mirror has dust on it easy fix
remove front of screen by removing screws around the top and sides of the back don't forget to pop off the bottom cover in the front it just pulls off
then remove center cover screws
i could not disconnect the front electrical plug but it has enough slack to lift and then tip the front screen down to the floor
it will be obvious on the mirrors there is a big one it wasn't to dirty
lean in and look down there is a small mirror and lens they were filthy
there is a piece of foam trying to keep the dust out it was sucked backed so dust could get in
clean with windex and paper towels cloth didn't work
good luck
Nov 08, 2008 | Mitsubishi WD-62525 62" Rear Projection...
How to get to mirror and lenses on a pioneer SD-643HD5?
unplug tv. Remove 4 screws from bottom of tv in front right below speakers on right and left side. Bottom panel slides up and out. Don't disconnect just rest panel on front of tv. Remove two screw at bottom of trim strips on each side of screen. Each one of these strips will slide down and remove. Last piece to remove is trim strip at top of screen. There are no screws to remove. The whole piece simply slides to the right about 2" to 3" inches then will unlock from mount brackets. Pull towards you and slide up and off screen. carefully lift screen up and out of bottom brackett. Top trim piece may be a little tight. Just tap on it with the palm of your hand and have somone pull on strip from other side.
Oct 18, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Water behind screen
Did you just sell your TV? Because if you did, I'm probably the one who just bought it. Paid $200. Anyways, if not, I did fix it. I dismantled the TV, starting with the bottom. Pull off the speaker cover then unscrew everything on the bottom in order to loosen the top screen portion. Unscrew the top screen and pull it off slowly, disconnecting the one wire that connects it to the rest of the TV. Once the screen is off, you can seperate from the frame it by unscrewing it. I then cleaned both screens (there are two layers) with distilled water and a microfiber cloth. You might be able to use other cleaning methods but I recommend plenty of water and then a non abrasive cloth. Make sure it's clean and dry before putting it back up. Picture is like new and I love it!
Jan 20, 2008 | Toshiba 51H84 51" Rear Projection...
Sony bravia 50 inch projector tv kdf-50e2010
how do you remove the screen from sony kdf 50e 2010 i have removed screws from top and sides of tv but cant see how to release bottom of screen
Nov 07, 2007 | Projection Televisions
VS 50605 screen replaced
first of all wally heres what to look for. remove speaker grill not sure of your model. speaker grill should pop off. then you will see screws holding the large plastic screen assembly. noww if you look there might be a group of wires going up to screen,they will be atatched to small plugs unplug them, remove small screws on bottom of screen assembly, entire plastic screen assembly will first slide up then pull away put assembly flat on floor (don't scratch screen put on carpit or sort surface ) screen side down. all around plastic screen you will see brackets with screws holding them on remove top,bottom,side bracket carefully put screen back in making sure the front side of screen is down replace brackets if plastic is not damaged should screen in place.reverse order of removal. remember alittle up then screen will slide down in groves doc
Aug 13, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Water behind screen
Did he think the programming stunk or something??? lol sorry. Sometimes the screens or lens is truely what they are are two piece type lens, depending on the make and the age of the set. On two piece screens (or lens) theres an outer type called a linticualar lens and the inside is like a light house lens as its called a freznal type lens. On Some makes and models these come apart BUT also in some makes and models they are a one piece design. as theres an inside ground lens and the other side is another ground lens. But im woundering if yours isent the two piece type that could be taken out and separated and cleaned as why would it suck up into the lens if it wasent??? I would call a specialist and ask them if its a two piece and could be cleaned or is it a one piece. Try calling toshiba first so you know what it is so you dont get ripped off so the repairperson wont pad the bill. Good luck Oh try calling this # first. 800-457-7777
May 25, 2006 | Toshiba 46H83 46" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
