GE APN10AA Portable Air Conditioner
Problem for GE APN10AA Portable Air Conditioner
Fan that cools the condenser does not come on untill i give it a small push
By danielevans1 on May 26, 2009
Clarification Request
Posted by lsteward68 on May 26, 2009
If the motor then turns to top speed after you turn it by hand then the motor is not bad. there should be a starting capasitor somewhere in line with fan. the capasitor acts as a starter for the fan by storing power then releasing at a certain amperage to push the fan on. Do you see this. You maybe able to take this to radioshack or purchase this online
Best Solution
posted on May 26, 2009
Very Helpful)
skeeter140
Rank: Guru
Rating: 89%, 153 votes
You will need to replace the motor. It is going bad new fan is about 125 bucks takes about 2 hours to replace unless you have the right tools then about 45 minutes. Be sure to pull the safety disconnect on the side of the house before attempting to replace. Be sure to make note of wiring. Can cut off the wires and leave in place then just wire nut new wiring to old. You will have 3 wires and 2 wires for the direction of rotation. Need anymore help just get to me ken
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE APN10AA Portable Air
Questions and Unsolved Problems for GE APN10AA Portable Air
Do you recommend GE APN10AA Portable Air Conditioner?
Answer
Answer
Only a small amount of the water gets to the drip pan of my portable room air conditioner(APN08 or... (More)
Answer
Won't drain into the bucket, it is bone dry. Water does seem to get all over the floor though.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
