Question about Nokia 6600
6600 face plates
How do you get the face plate off the fone dont want to break it?
  • 425 Answers
Actually thiers an opening tool for that, but we can improvise it. find an unused credit card, pvc ID or the like. use its edge to open it. insert the edge of the card to the bottom edge of the casing in an upward direction and slowly rotate it card in a clockwise direction gradually until you hear snapping sound. continue rotating it until you reach at the other edge...
hope you open it...
Posted on Oct 21, 2007
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
How do i take the face plate to check the cd drive an belt?
Stick your thumb in the USB slot on the face-plate, grab the end with your fingers and pull. Just be careful to not break the USB cover on your face-plate.
Apr 28, 2012 | Microsoft Xbox 360 Console
2005 subaru outback ll bean edition, center console or "bezel" is one plate with 6 cd changer, heat, etc.. all on same face. 6 cd changer will not work , i have 6 cd's stuck in there, just...
Is car automatic? dont matter, open arm rest and take out every screw u see, dont be scared move foward. pull up on shifter plistic beseil, then to ashtray,2 screws under, coffee thing gotta go.comon guys? can ya get gas in it? its looks like it will brake,just give it a quick ****...
Jan 04, 2011 | 2005 Subaru Outback
My Nokia 6600 no. 2 key is not working??
the picron switch behind the numeric 2 may be broken but in most cases its due to fluid built up between the two points you will have to have the face plate taken off and the key pad cleaned should fix it
Oct 29, 2010 | Nokia 6600
Skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Mar 14, 2010 | Singer 5062 Mechanical Sewing Machine
Got a Kenwood KDC-PSW9524. For some reason the
MINE DID A SIMILAR THING THE FACE PLATE IS MOTORIZED AND GOT STUCK CLOSED SO INSTEAD OF BREAKING IT I FOUND THE RESET BUTTON ON THE RADIO IN THE FRONT ON THE SIDE ITS A LITTLE TINY BLACK HOLE STICK SAFETY PIN OR SOMETHING IN IT.BUT BE CAREFUL IF YOU DONT KNOW YOUR RADIOS SECURITY CODE IF NOT SURE WHILE STILL ON GO INTO THE OPTIONS AND TURN THE CODE ACCESS OFF.!
Apr 12, 2009 | Kenwood KDC-PSW9524 CD Player
I have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Nov 09, 2008 | Dual XDMR-7700 CD Player
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
Nokia 6600 Logo
48 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
