Question about Kenmore 36 in.33392 / 33394 / 33399 Gas Cooktop
Knobs will not turn at all.....not to ignite or at all
I bought the cook top used and the contractors installed it in my new house, but the knobs wont turn at all.....no matter how hard or soft or pushed in or anything. Whats up???
    Novelist:
  • 222 Answers
Try to remove the knods then put a drop oil in knobs to remove the dust or try to use vise grip to help u to turn then if turn return the knobs but carefully to turn the knobs if u ise visegrip or plier
Posted on May 29, 2009
Simpson EZISET cooktop control knob does not turn
Take some electronics contact cleaner, CRC is best, and spray the knob. It has grease inside that is preventing the spring from popping it up so it turns. You'll need to get a new knob eventually and please don't install it yourself unless you are well versed in working with gas.
May 08, 2015 | Cooktops
Spill water on cook top by gas knobs. now the igniter is clicking on all the time with the knobs in the off position
Each of the knobs has a little white rotary switch on it's shaft below the cooktop. You've likely got water in one of those switches and it's making the connection in the switch to start the igniter circuit. Unplug/turn off the breaker to the unit. If it's just water and not a sauce or noodle water or something else impure, you may be able to let it dry out without too much trouble. You could try pulling off the knobs and sucking at the openings with a wet/dry vac to try to get more water out of the switches. The worry is corrosion from being wet too long. If it isn't working after drying out, you'll need a new set of switches. http://www.appliancepartspros.com/part_details.aspx?part_id=3185909
Mar 16, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
Flames too high Jenn-air CCG2423
Definitely cut your loses and get a cooktop with a warranty. That unit sat on the back shelf for a reason.......it didn't work properly.
Also, but a cook top that is compatible with the safety knobs they sell as child guards at places like lowes and home depot.
here is a link to show you how the child proof knobs work
http://www.associatedcontent.com/article/327577/childproof_your_stove_safety_1st_stove.html
Jun 20, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Jenn air jgc9536
yes , but that could be the manufacturers design or the wrong knobs
Oct 18, 2008 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Jenn Air gas cooktop
pop me an email at b4829@yahoo.com and reference your cook top you can rate me later
Mar 29, 2008 | Cooktops
Spark continuously on
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
Nov 20, 2007 | GE 30 in. JGP336 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Kenmore 36 in.33392 / 33394 / 33399 Gas Cooktop Logo
241 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
