Question about MTX Road Thunder RT-1240 Car Subwoofer
Hole in subwoofer
Son poked G.I. Joe head through 12" sub with foam surround. how can i glue that or patch it?
  • 655 Answers
Hello colinomalley,
You can repair the hole using a flexible permanent adhesive. If all of the cone is still there, I wouldn't use a patch. I'd just put the jagged edges back together. If part of the cone is actually missing, you will need to patch it. Thin fiberglass cloth works pretty well. Use painters tape that will remove easily and cover the hole from the rear of the speaker. Cut the fiberglass cloth about 1/4" larger than the hole and attach it using a silicone based flexible adhesive. Allow it 24 hours to set up completely and then remove the tape from the rear.
A product called "shoe goo" works very well for speaker repairs. It's strong, flexible, and permanent.
Hope this helps.
Posted on May 26, 2009
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
The foam surround on my subs are cracked and torn. I need them repaired. Would it be more ideal to buy new subs or get these w7's repaired?
wow i won't throw them away or anything like that. You can always go down to your local JL Audio dealer to see how much to refoam the subs. Lot cheaper then buy new ones..... That's the way i would go.. Hope this was helpfull
May 20, 2010 | Jl Audio 13W7 Car Subwoofer
Repairing 1/4inch tear in foam around sub
click the picture for product website
I used this stuff to repair a tear in the rubber surround on a kicker solobaric 10", it has held up for 10 years, seal the front and back if possible and allow to dry/cure completely. good luck :)
Feb 14, 2010 | Car Audio & Video
Speaker cone is rip
that sucks. Expensive sub. If its under warranty go that route.
If its not under warranty, you can repair it with epoxy.
Go to Lowe's and get a 2 part epoxy. Mix it and seal up the crack with the epoxy. Put it on thick because the sub is going to vibrate it like mad and it needs to hold up.
Jan 21, 2010 | Jl Audio 13W7 Car Subwoofer
I poked a hole in my subs what would b the best thing to use to gurantee a permanent yet tuff seal
Cone or surround?
How big?
I did the exact same thing as-well when I worked audio installs. If you slipped with the drill and poked a hole through the rubber or foam surround then you want something flexible and strong. Silicone works great and it holds really well as long as the surface is clean and DRY when you apply the adhesive. Not to mention it comes in many different colours.
If you punched the cone then you want something similar to the cone material...light and stiff. Depending on the material I would use a small amount of polyurethane or epoxy.
hope this helps!
cheers,
Jan 20, 2010 | Rockford Fosgate Car Audio & Video
I got a lil tear on the foam under my 12' alpine sub by where the terminals are...how do i patch it up or with wut??
a flexible adhesive like clear silicone adhesive will work, just don't glop it on too heavy or it will unbalance the weight of the cone and shorten the life of the sub. Dont use an adhesive that dries to a hard state or it will actually tear the foam more. Let me know if that helped:) Thanks
Jun 17, 2009 | Car Audio & Video
I have a little rip on the subs ring
The little rip on the foam surround can be repaired easily with some pure silcone from a harware store. Make sure it's pure silicone, because the silicone mixtures may deteriorate the foam prematurely. Also, all you're really doing is plugging the hole that the rip makes so that air doesn't leak out and further damage the surround and also affect your sub's performance. You'll need to apply a thin to moderate coat of silicone to the rip, and make sure that some gets into the rip. Do NOT use globs or big lumps. You should apply some silicone to your finger, and carefully apply it to the area. Try not to get too much on the inside/backside of the rip. If you'd rather just get a replacement sub, you should be able to find the raw driver on eBay or at a local MTX dealer.
May 18, 2009 | MTX RT12X2-200 Car Speaker
Which Jl Audio 12 Has No Writing On The BAck
http://www.simplyspeakers.com/speakerrepairinstructions.htm
go with the repair .those r good subs,very expensive. i repaired a pokl 12" sub cone and surround foam. never had a problem. save me 300 bucks.the cone you can fix by using the same material that it is made off.if paper use rubbeer glue. if plastic ,i used a 2 part epoxy,airplane glue.didn't look pretty but did the job.rating please
Feb 03, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Cerwin Vega 12D4
if the holes not very big then it wont efect it (the size of a pinki nail)but if its a little bigger then use some real good silicone. put a piece of real thin paper on the back side of the whole and put a thin layer over the paper then get as much of the paper off as u can
Apr 29, 2007 | Cerwin Vega 12D4 Car Subwoofer
MTX Road Thunder RT-1240 Car Subwoofer Logo
460 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
