Question about Carrier Beverage Air DD68C Commercial Beverage Dispenser
Ice maker won't work
Franklin Icemaker HDIM35. Will not make ice. Lights on panel are flashing, and makes a high-pitched alarm-like sound. When I unplug and reset - the "wash" cycle works, but no ice formation when I set to ice.
  • poodyjay Apr 23, 2010
    I need this answer also
fridgetech
  • 473 Answers
SOURCE: ice maker makes very little ice
You can't adjust it to make ice faster.  It should make 8 cubes about every two hours.  After it fills look and see how many cube molds are filled with water.  It may be that the tray is not getting full.  If it isn't filling the whole tray then you have a low water pressure to the fridge issue.  The most common problem I see is people use a self-piercing saddle valve on the water line and they get plugged and this drops the water pressure to the fridge.  If you have a self-piercing valve it needs to be changed to a drill type saddle valve.  If the saddle valve is the correct one and the tray doesn't fill all the way then replace the water valve on the fridge.  Let me know what you find.
Posted on Oct 17, 2007
watugot
  • 290 Answers
SOURCE: icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
SOURCE: ice maker will not make ice
www.searspartsdirect.com has parts for most machines, including HDIM35.
Posted on Apr 18, 2008
22yooper
  • 828 Answers
SOURCE: Franklin Chef FIM120 Ice Maker
http://www.tapplastics.com/shop/product.php?pid=12
If the damage is limited you can repair it by patching with a Epoxy such as you will find at the above URL.
Posted on Jul 01, 2008
Whirlpool Ice maker broken
First review this YouTube video about how to fix a current Whirlpool ice maker that does not make ice. Most are fixable. (The maker of the video, Repair Clinic, will work with you to find the exact part needed and sell you that part. Excellent company to work with.
Whirlpool Freezer Won Make Ice Ice Maker Assembly W10190965
You can determine which ice maker you need by checking at the Whirlpool website on icemakers.
Whirlpool Refrigerator Ice Makers Replacement Parts Accessories PartSelect
If you have determined that you cannot fix your existing icemaker, try checking Amazon for a replacement.
Amazon com whirlpool ice maker replacement
Feb 09, 2018 | Whirlpool Refrigerators
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
I have a Jenn Air JRSD209W refrigerator. The ice maker stopped making ice. So far I have replaced the water supply solenoid and the ice maker unit. The unit is cycling mechanically, but no water is...
Check the water line that goes from the water fill valve to the ice maker to see if it's frozen shut.
You can remove the ice maker water line from the water fill valve and see if you can blow air through it. If you can't blow through it then its frozen shut.
Sometimes they freeze shut if the water inlet valve was seeping a little water past it when it was off.
If that is the case you have already replaced it so after thawing the water line out you should be good to go.
Aug 03, 2011 | Jenn-Air Refrigerators
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
U-line model ulr-60b
hi,
periodical clean can smooth the operation of your ice maker.
at this link you can have the ice maker cleaning guidelines:
http://lib.store.yahoo.net/lib/usappliance/echelon-icemaker-manual.pdf
Sep 09, 2008 | U-Line Refrigerator Ice Maker
U-Line BI-98 How to Remove Ice Maker Unit??
There is also a screw on the bottom of the icemaker. remoce it also.
Jun 19, 2008 | U-Line Icemaker
Ice maker will not make ice
This is a Franklin ice maker and here is a link to the manual http://www.franklinchef.com/pdf_info_phase_4/FIM35%20C%20Manual.pdf.
Nov 14, 2007 | Carrier Beverage Air DD68C Commercial...
Carrier Beverage Air DD68C Commercial Beverage Dispenser Logo
47 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Davor Krstevski
Davor Krstevski
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
