Question about RTO Sunpro CP7558 Tachometer Adaptor
How do i wire this tach to my car
I got a sunpro tachometer with 4 wires, red, black, white and green. I don't have any instructions on how to wire this to my car. It didn't come with any as I got this in trade for some other car parts. how do i wire this tach to my car
  • 376 Answers
I bet if you called... http://summitracing.com/ and asked for tech, they could tell you.
Posted on May 26, 2009
How to wire the tachometer
Red goes to the ignition switch fuse for power in the fuse box green goes to the the negative side of the distributor white is for the tachs light so it will go to the dash light fuse in the fuse box and black is for the ground.
Oct 21, 2012 | 1993 Mercury Capri
I seem to have lost the instructions to my SUNPRO Super Tach ll and my SUNPRO Air Fuel Ratio guage. I am installing these items in a 1998 GMC Sonoma P/U.
I don't know which one you have
Sun Super Tach II
  • 3 3/8" Chrome Bezel / White Face - CP7903 ' Link
  • 2 5/8" Mini Chrome Bezel / White Face - CP7911 ' Link
  • 3 3/8" Chrome Bezel / Black Face - CP7901 ' Link
  • 2 5/8" Mini Black Bezel / White Face - CP7904 ' Link
  • 2 5/8" Mini Black Bezel / Black Face - CP7906 ' Link
  • 2 5/8" Mini Chrome Bezel / Black Face - CP7908 ' Link
StyleLine White Face Electrical Gauges
Electrical Air Fuel Ratio - CP8200 Link
Sport ST Electrical Gauges
Electrical Air/Fuel Ratio - CP7011 Link
Jun 17, 2011 | Televison & Video
What do the symbols P and S stand for on terminals of the tachometer? 1978Chev.305 gas engine with distributor and coil.......jn my boat
tach hook up for chevy with hei distribitor is 1)white wire ; 12volt source 2)red wire -12 volt ignition switch (+) 3)black wire -battery ground (-) green wire ; to tach terminal on dist. / if it not hei with points just put green wire to neg. (-) side of coil
Nov 05, 2010 | Chevrolet Caprice Cars & Trucks
Trying to hook a tachometer to a 93 gmc seirra 1500 350 were does the green wire go?
The "Green" wire from the tachometer should be attached to the negative side of the ignition coil only, and usually (but not always) it is a black wire with a white stripe or it is a solid white wire that will come off from the negative side of the ignition coil and often has a tab on the wire that says "Test" or "Tach" and the wire ends with an open black connector that is used for connecting a diagnostic device or tachometer for diagnostic purposes, and this is the wire that the green wire from the after-market tachometer should attach to. The "Red" wire should be attached to an "ignition" source connection on the fuse panel and have battery power when the key is in the "Run" position only, the "Yellow" or "White" wire should be connected to the "LPS" source on the fuse panel, and the "Black" wire should be connected to a good ground source and if the tachometer is not properly grounded then you will get a primary voltage shock from the ignition coil every time that you touch something metal inside of the vehicle. Let me know if you require any further assistance.
Oct 19, 2010 | GMC C1500 Cars & Trucks
I1999 dodge ram 1500 5.2 and need to no how to put a tach in
Red wire would go to ignition battery, the black to ground. The third wire, probably green or blue, goes to the negative side of the ignition coil. Is there a wire for dash illumination?
Mar 10, 2010 | 1998 Dodge Ram 1500 4WD
How do I hook-up Sunpro Super tach 2. Wires: 1 each - green, red, white, and black? Or in general how do these type tachometers hook-up?
I've got an install diagram for that around here somewhere but for now, the trigger wire to run the tach itself goes to the "tach" connection next to the "Bat" terminal on the distributor cap. one wire attaches to your dash lighting so it comes on with the dash lights and dims properly, the other wire is likely a ground. If I don't add to this later, try googling Sun electronics...I am fairly sure they have an install page.
Jan 04, 2010 | 1985 Chevrolet K1500
Autometer tachometer installation
I have a 09 cobalt, and i cant figure out which wires and where do i hook them up to so i can use my after market tach
Oct 02, 2009 | RTO Autometer Auto Meter 6121 Cobalt...
2003 E350 tach pickup wire??
Tachometer Wire Negative Wire (-): Any Wire That Is Note Red/Light Green. The diesel tach wire is a green/white wire, located in a 5-pin harness held up with tape behind the parking brake release.
Tachometer Wire Negative Wire Location: At Igniton Coils
According to wiring diagrams online... good luck with this.
KEn
May 04, 2009 | Ford E-350 Super Duty Cars & Trucks
Hooking up a tachometer in a '94 Ford Escort with Distributorless Ignition System
Check with your local autoparts store for a repair/maintence manual. the manual will have the wiring schematics for your car. good luck
May 02, 2009 | Computers & Internet
RTO Sunpro CP7558 Tachometer Adaptor Logo
449 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Vuk B
Bill Boyd
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
