Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
Slide mechanism jammed
I have a Ryobi dompound slide mitre saw (don't know model no.) and both rails are a bit rusted, I went to use it the other day and the slide mechanism is jammed - doesn't seem to be because of the rust though, it sounds like something is knocking against something on the inside, it moves about 4-5mm and that's it (it's jammed half way along).
I've tried to take the backing plate off to have a look inside but can't get the screw undone - the screwdriver just strips the head of the screw (I stopped when the screw wouldn't turn, I didn't actually strip it!).
Also, the locking knob for the slide is intact, hasn't broken off in place, the end of the knob still has the machine finished end.
Any suggestions?
    President:
  • 1,996 Answers
Try squirting WD 40 all over the rails and into the bearings...Your bearings could have rusted in place and won't turn. Or maybe one is rusted and the other turns a bit...You could use a good pair of vice grips to remove that stripped screw.if that will give you better access..
I haven't ever seen one jammed up like that though...
Otherwise, you might look up the parts diagram and see what you're getting into there, if there's anything that could have broken off inside that's hanging up..link here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
My ryobi 10 in slide mitre saw does not collect
The tube that is directly behind the saw blade if full of splinters or sawdust. Remove the debris AFTER unplugging the cord.
Oct 04, 2014 | Saws
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I bought a new mitre saw and have misplaced the opperating manual. I don't seem to be able to release the saw so it will slide back and forth on it's tubular arms.
Often there is a bolt with a knob or wing nut head which has to be unscrewed to allow the rails to slide.
If you give me the make and model it might be possible to find a manual.
Jun 28, 2011 | Ryobi Garden
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
Apr 19, 2011 | Ryobi 10 In Miter Saw With Laser
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
Why when i cut a bit of 6" skirting board it does'nt cut square on a brand new ryobi ems 2026 sliding mitre saw
Don't ever assume that the markings on the angle setting are correct and accurate. Always check squareness with a square before you use a miter saw. With almost all brands of power tools being built overseas nowadays there is unfortunately a question of accuracy on most brands. Always check.
Mar 16, 2009 | Dewalt Mitre Saw Workstation
Makita 10" Dual Slide Compound Miter Saw with Light LS1013F Logo
116 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
