Question about Yamaha DSP-A1 Receiver
Pop from speakers when using dolby digital mode, works fine when not using any processing mode
I have a Yamaha DSP-A1 that I bought new in 1998. I've had it hooked up to various DVD players over the last 10 years and it's always worked fine. Recently, when I'm watching a DVD, and if I select one of the processing modes, like Dolby Digital, or Concert Hall, I'll get a steady 'pop' out of the speakers. I have 2 front main speakers and a center channel speaker hooked up, all PSB brand, all the same ones this has always had connected. Do you have any advice on solving this? thanks Dale
    Problem Solver:
  • 5 Answers
Over 10 years old? Could be bad capacitors... if you have the expertise, you can try taking it apart and checking them with capacitance and ESR (equivalent series resistance) meters. Otherwise, you can try to see if any capacitors are exhibiting any "bowing" or leaking; if the top of the capacitor is bowed or puffed out - even slightly - or if there is a brown or white residue around the base of the capacitor, you can guarantee the capacitor is bad. Note that not all bad capacitors exhibit these physical attributes... but you can be sure a good capacitor won't.
If all of this sounds too complex, your only recourse will be to take it to a reputable electronics service shop.
Posted on Oct 31, 2009
Denon Avr-3200 Dolby Digital not working
What I suggest is that you reset the receiver as you mentioned. If you look in your owner's, there will be a procedure that says, "Return to factory default, or Reset" I believe you have it set wrong, or are not providing it with Dolby Digial signal. Dolby Digital, is not processed by the DSP board(Digital Sound Processor), which handles the THX, Neo, and every other format. Dolby Digital, is one of the earliest form of Home Theater. It has to be processed through the 2 RCA jacks(left and right). It is really not used anymore, in light of Dolby Pro Logic, THX and others.
Dec 14, 2012 | Denon AVR-3200 Receiver
YAMAHA DSP A1 WONT SWITCH ON
Popped power supply hi sorry if you can't get it on trying to do a diagnostic won't matter if you can open the back check where the power is going into you will c a power supply board a cap has carrots on it check if any of them is popped up
May 20, 2012 | Yamaha DSP-A1 Receiver
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
Yamaha DSP-A1 sound drops at startup
In the manual it says switch off leave for 30 seconds and switch back on .
Aug 07, 2009 | Yamaha DSP-A1 Receiver
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Please Help about a Yamaha DSP-A1
The A1 has an internal self diagnostic program which you can go through to find the fault. You can access the diagnostic program by simultaneously pushing some buttons on the front panel. The Yamaha service manual for the A1 tells how to do it and what the diagnostic codes mean. You can get a copy of the service manual on the web from several suppliers for a small fee.
Jan 08, 2008 | Yamaha DSP-A1 Receiver
Volume level dropping unexpectadly
Nov 18, 2007 | Yamaha DSP-A1 Receiver
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
DSP-A1 Power Off
i am no expert but i had simmilar problems and it turned out that some capacitors needed replacing
Oct 25, 2006 | Yamaha DSP-A1 Receiver
Yamaha DSP-A1 Receiver Logo
230 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
