Konica Minolta bizhub C250 All-In-One Laser Printer Logo
A
Anonymous Posted on Jan 08, 2014
BizHub error code c3421 - Konica Minolta bizhub C250 All-In-One Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jun 27, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913024
Points
11959
No such code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error code c-3421 in bizhub c220
Hi
The following site gives error codes for a wide range of printers and their user guides can be obtained as well.
Error Codes Konica Minolta bizhub C220 Code C3421
Your error comes up as follows:-
Code:- C3421
Description:- Fusing heaters trouble (Heating side)
• Detected temperature of the heating roller thermistor/C does not go up a given range of temperature even after a lapse of given period of time at warm up. • Detected temperature of the heating roller thermistor/C does not reach to a given temperature even after a lapse of given period of time after warm up is completed.
Remedy:- 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 6 Change PRCB. 7 Change DCPU.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Bizhub c203 with c3421 error code
http://www.oasq.com/how-to-clear-error-code-c-3421-on-konica-bi-thread-733519-1-1.html
C3421 bizhub c360
fusing unit problem not heating up.generally replace.
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
Error code f-26-3
the bizhub 222 typically does not not throw this error code this is an error code is for one of the older konicas and is a toner density error code check developer/ developer unit
if this is a bizhub 222 the toner density error code would be c2557
Konica minolta bizhub c353 replaced fusion unit, and still have the error code, it will not reset
You did not mention the specific code. But if it is a fuser warm up failure code such as C3421 or similar you must use the proper reset procedure for the code.
Here is the procedure. If it does not work for you then reply with the code/indication you have and I will address it.
1. Turn OFF the main power switch.
2. Turn main power switch on WHILE pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
