Question about JVC KD-SX770 CD Player
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello, there. I recently acquired a late 90's Toyota Corolla with a JVC KD-SX770 stereo/CD player. The radio works fine, but it will not play CDs. When I insert the CD, the player tries to read it (at least I assume it does--it just says "PLAY" with no track number or other info showing) but then gives me the "please eject" message. I checked to see if I had the CD upside down, inserting it face up and then face down. I've tried both burned CDs and original copies. I don't know what else to do, short of installing a new stereo.
Any thoughts? Does this happen often with this particular model?
Thanks in advance,
Barbara
I'm having the same issues w/mine. I've cleaned the connections between the system & the faceplate & tried the reset button but neither seem to work. As for running a cd cleaner disc thru the system.. it treats it the same as a normal cd.... 3 to 6 seconds after inserting it, "please eject cd" pops up on the screen... it's annoying as anything
Posted on Aug 21, 2010
  • 655 Answers
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
Posted on May 26, 2009
2 Suggested Answers
SOURCE: JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
Posted on Aug 11, 2007
I NEED TO CLOCK SET
Please go to the link below page 20 will tell you how to set the clock.
http://resources.jvc.com/Resources/00/00/98/GET0019-001A.pdf
Apr 02, 2011 | JVC KD-SX770 CD Player
CD Player does not work. Can CD player be repaired?
If it is possible to repair only habria that to check it to repair the fault in general always checks what is the module of CD or the lens
Feb 03, 2011 | JVC KD-SX770 CD Player
I just purchased front speakers for my jvc kd-sx770. the connection to the previous fronts were cut by the previous owner of the car. i cannot find a wire diagram and just need to know what colors to...
front left negitive, white with black stripe front left positive, white
front right negitive, grey with black stripe front right positive, grey
I hope this has helped you and please dont forget to rate my solution.
cheers
Jan 15, 2011 | JVC KD-SX770 CD Player
Need help setting time on jvc kd-sx770
turn off the stereo then ull see the time only on ur set then u can set up!
Mar 14, 2010 | JVC KD-SX770 CD Player
How do you remove an upside down cd from a car stereo
1...Try and tease it out by using an old CD through the slot
2..If that doesn`t work then the player will have to be removed from the dashboard, the metal cover taken off and the CD extracted.
Make sure you have the security code BEFORE you pull out the player from the dashboard.
If you do not have the code
POST ANOTHER QUESTION quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
Oct 18, 2009 | JVC KD-SX770 CD Player
Dosent play burnt cds
Try to burn cd in 4x speed burn. Or try to burn the audio as CDDA format at lower speed burn.
Crackes usually appears when burn the cd at high speed.
Pls. leave a comment
Apr 10, 2009 | JVC KD-SX770 CD Player
No audio output from jvc cd receiver kd-sx770
The internal amplifier is at fault.
This will need to be repaired by a electronics repairman.
There is no end-user fix.
You may choose to, instead, use the RCA low level outputs and install a dedicated amplifier to power your speakers.
Verify the fuses on the radio are good, and that there is not a blown speaker causing the internal amplifier to shut down.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | JVC KD-SX770 CD Player
Kd-sx770
You can buy it from pacparts.com
Dec 08, 2007 | JVC KD-SX770 CD Player
JVC KD-SX770
May 18, 2007 | JVC KD-SX770 CD Player
JVC KD-SX770 CD Player Logo
976 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
