Question about Dryers
Makes loud sound when spinning - seems like off track
Feels like drum is off - makes screeching sound when revolving
  • Dryers Master
  • 8,220 Answers
The bearing is worn and now the drum support is rubbing against the metal mount. I do not know what type of dryer you have but my web page covers a lot of material. The dryer that is easiest is mentioned here, plus I have pages on your dryer as well.
READ MORE
Posted on May 26, 2009
I have a series 4000 maytag front loading wash machine. The problem is that it makes a loud screeching sound during the spin cycle
You have bad bearings on the drum. This is typical for Maytag and some other machines. A very expensive repair.
Jul 30, 2015 | Maytag Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
Hi, My Hotpoint TVM570 Aquarius is making a loud screeching noise occasionally. It isn't doing it every time my partner just used it for an hour with no issues. However I used it for 5 minutes this...
wonder if you are overloading the machine and the noise is the drive belt screeching. if it sounds similar to a loose fanbelt on a car, it could be drum bearings that are seizing up (check by manaually rotating the drum. if it spins freely its ok) or the drive belt is getting worn and needs replacing
May 09, 2014 | Washing Machines
Big Thunk when Frigidarie Front Loading washing machine started the final spin cycle, then at the end of the cycle soft screeching sound when drum is moving back and forth, any thoughts? amshap50@gmai
does not sound good. if you can remove a cover on front bottom or on the back you may find a broken shock, or counter weight, either would need replacing before running again
Jan 08, 2012 | Washing Machines
Makes a very loud sound when in the final spin cycle. Model MAH5500BWW
The sound of the tub spinning is a smooth and not ruff sound. and with speed it sounds like a 747 taking off ( when your inside not outside ) when the brgs go bad it will sound like a train on the tracks when your waithing to cross. ( very loud as it speeds up and very ruff. if you remove the 4 screws in the back can ck just below the center shaft. there may be brown water stains on the base frame . / water has got in the main brg . and the brg's are failing . hope this helped. mm. ( could be the drain pump / ck for coins ect. drain pump runs just before and during spin/ but not soloud like brg's.. **** .
Dec 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Dryers Logo
135 people viewed this question
Top Dryers Experts
