Question about Sewing Machines
I have a Bernia Activa 130 that my mother used for some time without any problems. I set it up for the first time today and have the following problem. The top thread works fine but it will not pick up the bobbin thread. I have re threaded the machine several times and made sure the bobbin and bobbin case were place right. Any ideas?
  • sdbarrettpow May 26, 2009
    Thanks for suggestions but none helped any more?
    Thanks for the suggestions but the prolem is still there. I am able to pull the bobbin thread to the top through the throught plate but when I begin to sew the top thread works fine and make the necessary loops through the fabric but it is not catching the bobbin thread to complete the stitch. The top thread unravels because there is nothing there to hold it to the underside of the fabric.
  • 749 Answers
Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
Posted on May 26, 2009
    Brigadier General:
  • 8,619 Answers
Hi
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual. You can place a Spool Thread on a Spool Pin.
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Re-Installing a bobbin into a bobbin case could be a good option
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
  • 3,741 Answers
The upper thread could be tangled. Remove the thread commpletely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle. The needle could be thread incorrectly. Thread the needle eye from the front to the back. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
please do rate the solution.thank you for using fixya.keep updated.thanks.
Bernina activa 230 sews a stitch then stops?
sounds like you bought someone else's problem, it could be mechanical or if the machine has a computer, that could be the problem, it would be a good idea to have the machine checked since it is used...
May 04, 2014 | Bernina Activa 130
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
Free print manual
there are Bernina manuals as pdf's on their website, www.bernina.com, then go to Support, choose your manual in the drop down box and download it. There is not one there for the Activa 130 but the 135 is there and the 125, both will be very close to your mode.
link is http://www.bernina.com/en-AU/Support/Machines/BERNINA-activa-135
Oct 13, 2012 | Bernina Activa 130
When I went to turn on my activa 130 it does not turn on. The screen just blinks.
sounds like connection problems with the board inside. a short of somekind. needs to be checked out.
Aug 17, 2010 | Bernina Activa 130
Won't turn on
Have you checked that the plug is pushed RIGHT into the machine?
Sep 15, 2008 | Bernina Activa 130
Needle always stops in up position
I have the Activa 131 and while the needle is made to stop in the up position, all you have to do is push the bottom of the peddle quickly with your heel and the needle goes into the material and stays until you start sewing again. Hope this is helpful.
May 25, 2008 | Bernina Activa 130
Owners manual
Unfortunately this is a purchase site. The closest I could get would be for an Activa 220 230 240 . You can download the manual.
Check the picture on no. 7 and see if this isn't your machine.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Hope this helps. Luck!
Dec 20, 2007 | Bernina Activa 130
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
