Question about Apache 3 Channel Micro Indoor Helicopter (Army Green)
Tremendous machine vibration
My toy apache helicopter seem to have broken one of the "A" main blades and the top connect buckle got lost, all happened after a crash into the wall. I replaced the "A" blade and connect buckle, but the machine is vibrating tremendously even at take off and it is not stable because of this vibration. It never had this vibrating problem before the crash and I've made sure the newly installed blade is free to move back and forth just like the other one is. Please help me with my problem Richard
  • 68 Answers
Make sure the "connect buckle" is connect to the correct side, and not bent in the middle, it should be straight. If this doesn't help, new blades are sometimes different weights try to matching the weight of opposing blades you may even need to sticky tape a small weight underneath the blade to get them balance. Don't stick anything on to the top of the blade.
Posted on Aug 31, 2009
Rc 3 channel apache helicopter how to replace balance bar without the tool kit provided
Cut the balance bar off until the pins are exposed. Use some pliers and squeeze the pin out and then put the new balance bar back on and put the pin back in.
I did it this way without the tool kit, my balance bar was already broken so it wasn't an issue to cut it. It worked for me, I am flying it right now.
Jan 02, 2011 | Apache RC Mini Helicopter AH-64
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
My helicopter wont come more than 6 inches off of the ground. What could be wrong? There is nothing tangled in it and the item is new.
sounds like remote control is out of adjustment. Instruction book if you have one shows how to null out the rotation i found that if not right to much rotation the main blades lose some power. When i adjusted it to cancel the rotation the copter lifted quickly. may be the problem. adjustment is on the lower rigfht of controler.
Dec 25, 2010 | Cobra Electronics Cobra RC 3 Channel Mini...
My helicopter wont fly the main propellers on top of the helicopter stopped working
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Apr 01, 2010 | Air Hogs Havoc Heli Helicopters
Will not stop spinnig to the left
The heli will do that if you hover less than 1meter from the floor ! or you may need to adjust the swash plate screws Look at them very carefully and draw a diagram if you remove a screw and replace screw into another hole , in case you want to put it back as it was?,Also remove two of those little [8]shaped hooks that tie the blades to the main shaft. Remove one from the top A set of blades and one from the Lower B set of blades You dont need to have all four connected at once.If you click on this link http://www.maplin.co.uk/Media/PDFs/N32FR%20manual.pdf it has the complete operating manual of your apache model in Pdf form (U Will need to download Adobe reader)
Oct 28, 2009 | Electric 4 CH Feral Beast AH-64 APACHE...
Yiboo AH-64 3D RC Mini Apache Helicopter, out of the box, charges, but will not do anything, channel C
Mine worked good for 3 days then died..Top blades wont spin.. It worked really well. The guy at (as seen on TV) shop that sold it to me actually seemed to tell me "Do not buy this!" But I bought it anyway at his word that I cannot bring it back no matter what after 24 hours..spent 90 bucks on this junk and there is NO SOLUTION
Oct 02, 2009 | RC Toys
I have an apache 3 channel helicopter.the top blades no longer spin so the helicopter just spins clockwise very quickly
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Sep 04, 2009 | Apache RC Mini Helicopter AH-64
Apache 3 Channel Micro Indoor Helicopter (Army Green) Logo
165 people viewed this question
Top Apache Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Apache Toy Expert? Answer questions, earn points and help others
