Question about Toshiba Satellite M105-S1021 Notebook
Toshiba Satellite M105-S1021 not getting AC power to it.
All of a sudden one day I was using my laptop with the AC connected and got the low battery warning light. So I assumed the AC power supply had failed. I ordered a new one and I have the same problem. At one point when I tried one of the two supplies I have on hand now (can't remember which but don't guess it matters) the laptop functioned normally and booted up and charged the battery. But the next time I went to use it with the AC power supply connected it discharged the battery again and after that I can't get power to it anymore.
What is the likely problem?
  • 33 Answers
My toshiba had a bad internal power socket and I went through the same steps that you did. I also replaced the battery. So now I have two batteries and two power supplies and had to pay to have the computer shop put in the internal socket that the power supply plugs into. Hope this helps
Posted on May 26, 2009
5 Suggested Answers
  • 43 Answers
SOURCE: I have a Toshiba Satellite M105-S1021. When it
Hi
That would be the BIOS password is open the ram compartment and pull up the plastic sticker or whatever you want to call it between the motherboard and the ram. There is a jumper called "CMOS_CLR1" use a screwdriver to short out the pins and it clears the CMOS.
Posted on Jan 08, 2010
Geekman
  • 32281 Answers
SOURCE: TOSHIBA SATELLITE M105-S1021 THE ATI
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Posted on Apr 19, 2009
rhari008
  • 68 Answers
SOURCE: Toshiba satellite M105-S1021
Probabaly there are many softwares installed in it. Please run thorugh a complete scan of the same with McAfee.
Regards,
HP
Posted on Aug 28, 2009
  • 8909 Answers
SOURCE: How do I replace the
You should remove the memory cover underneath your laptop first. There are several covers but only one is the correct one.
The modules unclip by way of the clips on the side of the modules.
BEFORE YOU TOUCH THE MODULES ensure that the battery has been removed and you have touched the VGA output socket, to discharge yourself from static, or the modules will possibly get damaged.
Only touch the side ends of the modules, (where the fixing slots are), to avoid damage.
Make sure the replacement module/s are of the same make and type otherwise you may get problems.
I hope this helps.
Posted on Oct 23, 2010
Factory reset toshiba satellite M105 S1021
Hold down the F8 key while you turn on the computer to start recovery. WARNING !!! This will delete your data and put the computer back to the way it was coming out of the factory.
Toshiba M105 S1021 Satellite Celeron 1 46 GHz User Manual Restarting The...
Feb 13, 2017 | Toshiba Computers & Internet
I need VGA drivers for Toshiba satellite m 105-S1021
You can download any orall the Windows device drivers for your model laptop from the Toshiba WEB sitefrom their download page. Make sure you enter the model of your laptop so youcan get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Apr 29, 2011 | Toshiba Satellite M105-S1021 Notebook
Bios password issue M105-S1021 I see that the Wireless card is under a small door on the back of the unit. Is there a jumper I need to short and which one. I get a lot of different solutions I was...
To reset the BIOS password read the information from this link.
Because it is under warranty the easiest method would be using software from Hiren's Boot CD.
Oct 23, 2010 | Toshiba Satellite M105-S1021 Notebook
I have a toshiba satellite m105-s1021. when i turn it on, i hear it running but the screen stays black...so i pluged vga to it. works fine there...looked around for errors, none, updated drivers,but no...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 12, 2010 | Toshiba Satellite M105-S1021 Notebook
Screen height and width of the M105-s1021
go to google type in make seriel and end with the word spec
Aug 03, 2010 | Toshiba Satellite M105-S1021 Notebook
I have a Toshiba Satellite M105-S1021. When it boots up ask for password. I do not have any password. How can I get in it?
Hi
Jan 08, 2010 | Toshiba Satellite M105-S1021 Notebook
No singns of life
Sounds as though your ac adapter is bad.But it could also be the power jack where the ac adapter plugs in also.
Aug 07, 2009 | Toshiba Satellite M105-S1021 Notebook
TOSHIBA SATELLITE M105-S1021 THE ATI GRAPHIC HAD BEEN DELECTED BY MISTAKE
Use this link :-.
Apr 19, 2009 | Toshiba Satellite M105-S1021 Notebook
Hi there, Just wondering if someone can help me. I just received today two 1GB memory modules so I could upgrade my laptop. Only problem is, It states on numerous sites that my laptop has two memory...
Here is the link for the Toshiba Satellite M105-S1021 manual. It is zipped and you can download it to your machine. It will tell you exactly how much RAM you can hold and where it is located.
Please don't forget to rate this solution.
Jan 09, 2009 | Toshiba Satellite M105-S1021 Notebook
Toshiba Satellite M105-S1021 Notebook Logo
247 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
