I can only get the machine to work up to the 3rd menu and I have tried several different disk and it won't change colors. The first one works fine but after that it will blink on the P2 and P3 and won't stay on it long enough to stich.
SOURCE: Designer 1
after 8 years of sitting, the machine needs to go to the shop so that areas that are inaccessabe to the sewer can be cleaned and serviced by the tech. also check the upper threading of the machine. the tension is changed if threaded incorrectly. bunching under the material is caused by several different reasons. I would first have the machine cleaned and serviced by the tech, and let them know it has been 8 years since use. we all begin walking by taking one step at a time.
del
SOURCE: Reading the Embroidery D-cards
I went back to the place where I purchased it and they told me that it was the difference with the size of the hoops. I had to adjust the hoop size before it would accept the settings. That solved the problems. I thought when it was calibrated, that it automatically reset the hoop size - not so.
SOURCE: For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
SOURCE: embroidery not working
If still an issue, suggest you visit an authorized Husqvarna Viking dealer for assistance. They are usually eager to help. It sounds like it may be time for the machine to be serviced.
You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
