Question about LG LB8000ER Air Conditioner
Air conditioner not working properly
Compressor is on, doesn't blow very cold air.
  • Cheryl Tomasi Roy
    Cheryl Tomasi Roy May 26, 2009
    We got this used from someone and it looks brand new, its only a couple of years old and was used in a guest room once or twice. Inside the unit looks very clean,should we try cleaning it anyway? How much does freon cost to replace if thats the problem. This is a casement window air conditioner which is very expensive to buy new.
  • Ken Bledsoe May 11, 2010
    Have you ever taken unit out and cleaned? Mainly the back where the condenser is?
  • 306 Answers
You can pull the inside of the unit out of the case to inspect the back coils mainly to see if there is any blockage. Note the screws on the bottom of the housing the holds the coils take the screws out and very gently take the coil and move out a little. It will flex enough to clean the coils. Just don't hit it with very high pressure water cause it will bend the fins that go around the coils. I have done a bunch of window units this way and you would not believe the difference it makes. Let unit dry out and re-assemble. Let me know if you need anything else.. ken
Posted on May 27, 2009
2 Suggested Answers
  • 5 Answers
SOURCE: Blueway split system wall air conditioning doesn't work properly.
need to add refrigerant
need to check wheather the ampere is the same on the name plate
check the room temp. setting
check the setting of the timer
Posted on Jan 26, 2009
Air conditioner is not blowing cold air
Hello,if the compressor is engaging than the unit has dirty coils or has no refrigerant in the system.
May 29, 2012 | Emerson Quiet Kool 12HT13 Air Conditioner
My ac doesn't blow cold
Can you hear the compressor starting? If so, suspect broken pipework and loss of refrigerant. If not, suspect loose wire to compressor or thermostat
Apr 19, 2012 | Dometic Rooftop RV Air Conditioner
My coleman mach air conditioner will blow cold air for around 4-5 hours then air is no longer cold? I could turn it off for a few hours and it will blow cold air again? what could be my problem?
sounds like the compressor is going in to overload this is a protection if it gets to hot make sure your condenser fan motor is working properly and that your condenser coil is clean I would rinse it out anyway to make sure. when you shut it down you are allowing the compressor time to cool down and it restarts but you have a high pressure head problem .
Jul 31, 2011 | Heating & Cooling
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
heatman101
Jul 23, 2011 | Danby Heating & Cooling
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
I have a ''GE"heat &
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
May 17, 2011 | GE AJCQ06LCB Air Conditioner
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
Air conditioner is not blowing cold air,
What pressure did you have? And Is the front of the compressor turning when you have this pressure. Also feel the two lines going to the compressor, one should be hot and one should be cold.
Jun 28, 2009 | 2000 Chrysler Town & Country
LG LB8000ER Air Conditioner Logo
285 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
