LG Bottom Freezer Refrigerator w/ Swing Freezer Door 22 Cu. Ft. - LRBN22514 Logo
A
Anonymous Posted on Jan 08, 2014
Lg fridge freezer gr p197 nis not freezing - LG Bottom Freezer Refrigerator w/ Swing Freezer Door 22 Cu. Ft. - LRBN22514
5 Related Answers
Anonymous
  • 489 Answers
  • Posted on Apr 29, 2008
SOURCE: LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Anonymous
  • Posted on Jan 30, 2009
SOURCE: lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Anonymous
  • 19 Answers
  • Posted on Feb 21, 2009
SOURCE: Refrigerator LG Model GR-T452G freezer works but
Locate your defrost timer, they are either in the buttom front of the refrigerator, in back of the refrigerator, or inside compartment behind the plastic covers. On the defrost timer there is a slot were it can be turned using a screwdriver, or there is a round window were you can see it running.when you turn this dial and it clicks, you should now go into defrost. with all the ice build up in your evaporator you should hear the ice cracking indicating that the heaters are working, if not you might have open defrost heaters.
Anonymous
  • Posted on Jul 03, 2009
SOURCE: HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Anonymous
  • Posted on Dec 18, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
What has caused my water inlet pipe feeding the ice making machine to freeze?
It seems there is some blockage in copper tubes ( capillary)
Need to flush internally and then refill refrigerant
LG GR-S512GCA NOT COOLING
check and see if compressor is kicking on and off after a few sec if it is you might try a hard start on the compressor its a little switch that goes on the compressor where the wires go cost around thirty dollars be worth a try before going out and buying a new fridge
1helpful
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
My freezer is working perfectly but the fridge is not
The channel in the back were the cool air comes down from the freezer to the fridge may be iced up. Try defrosting the fridge/freezer for much longer than usual, all day if necessary.
1helpful
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
7helpful
2answers
Mar 02, 2009 • LG LFD25860
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
