Question about GE GSD2000J Dishwasher
DISHWASHER TOP SHELF IS SQUEEKING AND STICKING.
DISHWASHER TOP SHELF SQUEEKS WHEN PULLING THE SHELF OUT AND PUSHING IT BACK IN. WHAT DO YOU USE ON THE TRACKING TO STOP THE SQUEALING NOISE AND MAKE IT GLIDE EASIER.
  • Anonymous Mar 18, 2014
    top shelf keeps coming off track, how can i remedy this
  • 423 Answers
One approach would be to apply plumbers grease to the wheel (simple) axles turn on. It would be if you can pull the wheels, apply the grease and reassemble the wheels. The plumbers grease can be bought in a tiny tin at any real hardware stores.
Longer term fix would be to replace the wheel assemblies with new/replacement parts.
Posted on May 26, 2009
My kenmore heavy duty extra large capacity 2 speed motor when drying my clothes squeeks when turning to dry clothes can I spray wd40 to make it stop squeeking and how or what do I oil?
Most likely a wheel bearing on the tub of a front loading washer, or the belt tensioner pulley on a top load washer. Either is not fixed by lubrication but replacement is called for. There are usually 3-4 wheels on front loaders that could be out. Replace all of them if you are going to replace one. The belt tensioner is a single assembly that can be ordered from any appliance parts warehouse or Sears.
Aug 01, 2012 | Kenmore Washing Machines
The sprayer on the roof inside of my dishwasher does not work. My dishes on the top shelf are stll dirty after a complete cycle wether on normal or pots & pans. I have the whirlpool Gold Quiet Partner...
I'd look at the "spray holes" on the sprayer to ensure no clogs.
Next, ensure tube at the back (if I'm thinking of the correct model) of the top shelf meets with the spout sticking out of the baqck wall of the washer.
Jul 17, 2011 | Whirlpool Dishwashers
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Granddughter stood on dishwasher door and now it goes down too far when opening. Spring assembly (pulley type) is FINE...but door goes so far down bottom shelf nearly breaks dishes when pulling out
This happens when people leave the door down, I've seen it many, many times, sometimes the door/hinge assembly can be replaced or even bent back, sometimes it totals out the unit...Good luck !
RMK...
Retired GE Factory Service
May 21, 2009 | Dishwashers
Major friction/squeeking from serpentine belt!!!!
Keith,it sounds like you may need to clean the grooved surfaces on your pulleys,you could remove the belt and use some aerosol brake cleaner and a stiff brush to remove any build-up on the pulleys.you could also try spraying the same on the pulleys while the car is running,just be sure and wear eye protection and don't get to close to any moving parts.
Apr 29, 2009 | 1992 Mercedes-Benz 190
98 Ford Ranger Squeeks when accelerating
do you hear the squeeking in the truck only if so then its the little o ring plastic in the peddle makeing the noise.
Feb 04, 2009 | 2003 Ford Ranger Regular Cab
Top rack not being cleaned?
Make sure the water tower is not blocked so it can rise to that level. Check the condition of the tower by pulling it up gently. If it sticks, don't force it.
Jan 14, 2009 | Magic Chef 24 in. DU6550 Built-in...
My GE Profile Squeeks
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Nov 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Squeeking during wash cycle
Hi jbramwilliam
I'm Harvey the Master Plumber.
Sometimes this is caused because something is now rubbing. Make sure:
The screws are secure to the counter,
The d/w is perfectly level,
The legs are all tight to the floor,
If the back legs are wheels then shim with wood blocks.
If it still squeeks then you have a warranty problem.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | GE PDW8200NWW / PDW8200NBB Dishwasher
GE GSD2000J Dishwasher Logo
191 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
