Question about HP Pavilion dv5000z Notebook
HP Pavilion dv5000 running slow + weird sound problems
My HP Pavilion dv5000 laptop running on Windows XP has started experiencing various problems out of no where. First of all, it is incredibly slow to boot up, and then remains slow to even launch the simplest of programs, including IE. I haven't downloaded anything suspicious, only Firefox and a Flash and Java update - but it is since then that the computer has been running so slow... In addition to this, the sound is acting weird. I've tried streaming some music on Youtube when I first noticed that the sound keeps jumping in some parts, lagging in others, and seems to get stuck - almost like a broken record. This doesn't only happen when I'm online - music on iTunes as well as the sounds that appear when logging on and shutting down have the same problems.
It takes roughly 10 minutes for the laptop to finish loading all programs when logging on, another 5 minutes just for Internet Explorer to open, and then another 2 minutes for the homepage to appear. After this, the internet runs relatively smoothly, except the sound problems continue.
As mentioned before, I have no idea what may have caused this - it seems to have come out of no where, a day after installing Firefox and the Flash update. Today I removed both programs and rebooted the laptop, but to no avail.
This doesn't seem to be virus or spyware related, as I'm running Windows Defender as well as an updated version of AVG. Scans are done daily, and nothing suspicious has shown up. In addition to this, I have done a disc clean up and have removed any programs that I'm not using and won't be using in the future. I've also used HijackThis (I have experience using it), but absolutely nothing suspicious has shown up there either.
Any ideas what could be causing these issues? Any help would be greatly appreciated...
    President:
  • HP Master
  • 1,996 Answers
Are you running xp or vista? Are you on a dv 5000z or a zv 5000 z
This sounds exactly like something I ran into a month or so ago, but at the moment I can't put my finger on the fix...
I think it would be worth while to run a scan with MBAM, despite having Defender and AVG come up with nothing. There's a lot of malware that can slip by some of the best security systems if you simply download from the wrong site. You can get a free copy here.
The other thing I recommend is that you run chkdsk on your system, to make sure there's not some kind of file corruption at fault. You can see the log from this in the event viewer under winlogon by opening the properties of the 1001 code after it runs. Instructions are here and here.
In fact, if you haven't already done so, I'd look through the logs in the event viewer and see what kind of errors are reported there. That could help a lot to point out the error. link here.
The sound issue could indicate outdated drivers as well, and if you have an older system that could have some out of date hardware in it, here's a good tutorial for remedying that. If you're in fact running xp, you might want to work through this article for the sound problem...there's a similar one for vista.
If you're on vista, there's some registry fix for that sound issue, but in that case get back to me and I'll look it up.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
  • 431 Answers
Hi I am Vortash it sounds to me like you have one of two possible problems either your Ram module is corrupt or failing or your HD is if it is slow on initial start up I would go for Ram , However you can find that a corrupted partion can also cause this .. it may have a virus that your present software hasn't detected .. If it was left on your partion chances are it is hidden by the time your security software is started . I have actually only seen this once but as I say it may be a cause ., I would personaly save anything I could to a Usb drive and then do a total format of the disk deleting any partitions on the drive and starting again from raw .. or if you have another HD try it on the unit and see if there is a difference . If it is the HD you will notice a significant change if not , try unplugging the ram and refitting new if you can ,.. I think this also comes down to an economic question of age of laptop etc.. This is one of those see it questions ( I could tell better If I could see it lol ) another cure may be a service from Pc world or some other qualified engineering service outlet . sorry couldn't have been more help but as I say this is a question that needs hands on ... Regards Vortash
Posted on May 25, 2009
    Problem Solver:
  • 6 Answers
If the computer is making noise (that's what I originally thought was your problem, but now I don't think so), the only things that move inside the computer are fans. If the CPU fan is running slow, the CPU will heat up and cause the computer to run slow. If the CPU gets too hot, it will self-destruct. But you will get an error warning before this happens.
If you mean your computer is running slow and sound streams are interrupted, that is probably caused by software problems. Open Windows Task Manager by pressing and holding the Cntrl, Shift, and Esc keys simultaneously. The window which opens will show the %CPU usage at the bottom center of the page. This should be below 5% without any programs running. If it is higher, click on the Processes tab, then click on the CPU at the top of the column. This will show each process or program that is running and the % of CPU that it is using. Once you have clicked "CPU," it will list the processes in order of highest %CPU first. If you see that one or two processes are using a lot of CPU, record what they are and then highlight each one and click on "End Process." If this speeds up computer, good. You now know what program is causing the problem and can remove it or reinstall it.
Other ways to speed up your computer: Click on "Start" and then on "Run." Type in "msconfig" and click OK. On the System Configuration Utility page, click on the "Startup" tab at top right. This will show you all of the programs that are started when you boot up, and that are always running in the background. These programs will slow down the computer. See how many are checked. If there are a lot of them, click "disable all." Most of these programs are unnecessary. You will not lose any information or programs. Click "Apply" and then "OK." If a warning comes up about being the administrator, ignore it. Restart the computer. A sign will come up telling you changes have been made. Check the box to not let you know this in the future and click "OK." See if this has helped. If you had many programs checked before, it should make a big difference in boot time.
I hope this helps. It will at least give you are starting point for diagnosing your problem.
Larry
HP pavilion dv5000 running very slow
Go to www.acebyte.com this program is a all around utility and free, this will help with performance and speed even with a slow computer.
Apr 07, 2012 | HP Pavilion Computers & Internet
My laptop dv5000 hp pavilion has no sound after formating
Find the sound card, reinstall or update the driver. HP drivers can be found on the HP support site! Goodluck!
Dec 03, 2010 | Computers & Internet
All usb ports on my HP Pavilion dv5000 do not recognise any device attached to them. Hoevevr when thr same devices in pugged into another computer they work perfectly.
Unistalled the USB Generic Root Hub Drivers from the Device Manager by right clicking on the generic root hubs and then restart the notebook and This will fix this issue for you....:)
May 02, 2010 | HP Pavilion dv5000z Notebook
I cannot find part number for HP pavilion DV5000 Notebook?
This shows various tags for Pavilion DV5000 CTO, including p/n:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&tmp_task=prodinfoCategory&lc=en&dlc=&cc=us&product=499849&lang=
If those don't help and yours is not CTO, go to link below and select correct model. Click to that model, then choose "product information" on the right, then "product specifications," then "locate the notebook product number or model number." Scroll down to see sample tags.
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=1132551&lc=en&dlc=&cc=us
Feb 06, 2010 | HP Pavilion dv5000t Notebook
My Hp Pavilion dv5000 crashed! XP cd displays error message!
If you are facing this issue while installing Windows, Most probably there is an issue with the memory card. If you have two memory modules try to use one of the memory modules in each slot at a time. If you have only one memory stick then try to use it one by one on each slot. If you it does not work then probably you might have to replace the memory stick.
Hope you find this information helpful.
Thank you for choosing Fixya
Dec 22, 2009 | HP Pavilion dv5000z Notebook
Battery with HP Pavillion DV5000 won't work. Do I need to replace the battery or is there a battery charger I could use to recharge the battery? Dianne
You can order a power cable online or pick one up at your local computer store. They should run between $80-150. The battery itself is very expensive to purchase but is rechargeable.
Oct 22, 2009 | HP Pavilion DV4015cl Notebook
I need from HP pavilion dv5000 sound card driver.
i don't know which dv5000 model it's so, here they are
HP Pavilion dv5000 CTO Notebook PC
HP Pavilion dv5000ea Notebook PC
HP Pavilion dv5000t CTO Notebook PC
Step 1: Software & Driver downloads
Step 2: Select Operating System
Step 3: Driver - Audio (Select your sound car brand)
Don't forget to rate my comment.. Thanks!... (=
Jul 05, 2009 | HP Computers & Internet
Vista driver for huawei ets 2256
I will give you a easiest way for finding the drivers that you needforyour hardware.Just download the software named drivermagician.Installit and it will search for the drivers that is notinstalled for thehardware you have through internet and will downloadit for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
May 20, 2009 | HP Pavilion dv5000t Notebook
Don't stay on
You might have a bad optical drive. One way to test this is to get an external usb drive, enter setup (bios) upon start up, and change the first boot device to usb device\exteranal drive, then use the exteranal drive. If it works, then you know you have a bad drive.
Mar 23, 2009 | HP Pavilion dv5000t Notebook
Open Questions:
HP Pavilion dv5000z Notebook Logo
1,589 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
