Question about Maytag PAV2300 Top Load Washer
Maytag performa pye/g2200,3200
Stopped working in  rinse cycle, tub will not spin at all not even manually....
its like it isnt even plugged in
check breaker at panel not tripped,
could this be the motor,belt, trans,
no matter what position the dial is in it dont matter
its completely dead
  • 2 more comments
  • spankky Oct 20, 2007
    its full of water also...
  • spankky Oct 21, 2007
    YES ITS WONT TURN BY HAND
    if the bearings did seize up can they be replaced??? if so how much would the repair be any idea???
  • dean28 Dec 02, 2007
    washer fills but wont drain or go into spin cycle.
  • 64 Answers
When you say the drum wont spin even manually. Do you mean the drum is too stiff to turn by hand? If so the bearings may have seized up solid. If the drum is free to turn by hand, the pump may be blocked, or burned out & not allowing the water out. If so the circiut wont allow the machine to spin. If thats the case, unblock or replace the pump
Posted on Oct 21, 2007
  • keith wagstaff
    keith wagstaff Oct 22, 2007
    sorry, dont know how much it would cost to replace bearings. Suggest you phone a local repair company, tell them you think the bearings need replacing. Ask for cost estimate over phone, because most  companies have a call out charge. I doubt if its worth having it fixed. PS Im in UK, where are you?
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks ok............be careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
Feb 13, 2010 | Maytag PAV2300 Top Load Washer
Maytag performa washer during spin cycle tub is making loud banging noise and continues even when clothes are evenly distributed
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Jan 03, 2010 | Maytag Washing Machines
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
Maytag PAV2300 Top Load Washer Logo
687 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
