In my 2006 Toyota Tacoma 2wd 4cyl the fan seems to be blowing rather weak. With the fan on high it seems as if its hardly on, compared to most other vehicles. Is this normal for a tacoma or is there a way to fix it?
    Sergeant:
  • 145 Answers
Hi there, it is possible there is something obstructing the air flow. Switch the fresh/recirculate switch to recirculate does the airflow increase? Next you will have to remove the blower motor check the cage ,is it clear? Using a flashlight inspect the blower housing for debris,leaves,paper etc. Check operation of the blend and mode doors.
Posted on May 25, 2009
Where is the camshaft position sensor on a 1996 toyota tacoma 2.7 located.
Camshaft Position Sensor
1996 Toyota Truck Tacoma 2WD 2.4L EFI DOHC 4cyl
The Camshaft Position Sensor is located: Under hood, passenger side, front engine area, below valve cover, mounted in distributor
Oct 14, 2014 | 1996 Toyota Tacoma
2006 Toyota Tacoma Prerunner, 2WD, 4.0L V6, 5-speed Automatic has a severe vibration from the speed of 20 mph to 50 mph, then the vibration will slightly deminish.
Is it the engine vibrating or the car? If its the car itself it sounds like u need to have the tires checked & balanced.
Mar 16, 2017 | 2006 Toyota Tacoma PreRunner
2006 Tacoma fan blower only works in high.
the blower resistor is bad. find the blower motor and follow the wires to the resistor, its bolted to the air box.
Nov 24, 2010 | 2006 Toyota Tacoma
My AC/Heater does not blow any air in my 2006 Toyota Tacoma V-6 Pre-Runner. There hasnt been any whinning noise from a belt or anything... could it be the fuse or should i just take it to the dealer if its...
well it could be just a relay for the fan blower motor or a fuse. check all the fan positions..low med high..Its something you can fix but it if got about 600.00 dollars laying around .. take it to the Dealer..lol..Good Luck!!!
Nov 03, 2010 | 2006 Toyota Tacoma
06 toyota tacoma running lights keep blowing fuses
Where is the fuse for running lights on a 2006 toyota tacoma.
My radio & aa few dash lights are out also
Aug 31, 2010 | 2006 Toyota Tacoma
2006 tacoma airconditioning problem
Replace the fan motor resistor, which is located in the blower housing, (under the dash, under the glove box) to the driver side of the fan motor. Held on by 2 screws. Common problem. I change a lot of them.
Jul 23, 2008 | 2006 Toyota Tacoma
98 Toyota Tacoma 2wd, with 2.4 liter
You said like tune up fuel filter was done, wires.
Jul 05, 2017 | 1998 Toyota Tacoma
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
