Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Excess white smoke coming from exhaust of TB 75SS string trimmer
After mixing the correct ration of gas and oil there is excess white smoke coming from the exhaust
  • 1 more comment
  • terryterr681 May 26, 2009
    thank you for getting back to me. What I have read (don't have the manual) on-line is that this model (TB75SS) is a two-cycle trimmer and therefore needs the mixture. Is this not true?/
    Thanks again.
    Terry
    Regarding Troy Bilt TB 75SS string trimmer. After mixing the correct ration of gas and oil I have excess white smoke coming from the exhaust. Any help with this trimmer? Thanks,
    Terry
  • Anonymous Mar 15, 2014
    white smoke coming out of carburater and will nostop when pushing button
    Top Expert:
  • Troy Master
  • 76,846 Answers
1ST THIS TRIMMER IS A 4 CYCLE TYPE ENGINE (AS ALL TROY BUILT ARE) AND DOES NOT USE OIL IN THE GAS, SO THAT IS ALMOST CERTAINLY THE SMOKE PROBLEM PROBLEM HERE. IN A 4 STROKE ENGINE THERE ARE JUST A FEW THINGS THAT CAN CAUSE THIS SMOKE PROBLEM, ONE IS A DAMAGED CYLINDER WALL ANOTHER IS IS PISTON PROBLEM OR A BROKEN OIL CONTROL RING, ALSO ,MAKE SURE THE CRANKCASE VENT IS CLEAR, EXCESSIVE CRANKCASE PRESSURE CAN CAUSE SMOKE.
Posted on May 26, 2009
  • 125 Answers
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
Posted on May 25, 2009
White smoke from p1500 trimmer
Too much oil in the gas or water in the gas
Drain the gas, refill with fresh clean oil/gas mixture
Apr 03, 2016 | Poulan 25cc 2-Cycle Gas Powered String...
What oil weight is used in the TB 575
If it is a 2 cycle motor, then use an appropriate 2 cycle oil. I use a synthetic oil that 1 bottle is mixed with 1 gallon of fresh gas.
May 09, 2014 | Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Trimmer is producing alot of white/blue smoke, got it to start and it will keep running, but the smoke seems excessive when using it. Not sure what the problem is.
This engine does NOT used mixed gas at all! It uses straight unleaded gas. If your using mixed fuel of any mixture ratio in the engine it is really going to smoke badly. What fuel are you using please?
Kelly
Jul 01, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Occasional heavy smoke on tickover, but not using oil and oil clean.
HI do you now the color of the smoke
if engine emits white smoke its not burning the fuel
it could be water mixing with fuel = head gasket even tho you
dot have water in the oil
if engine emits black smoke - that's excessive fuel to air ration
check air filter & air inlet to see if clogged
if engine emits blue smoke - excessive oil consumption
cloud be valve seals
Jun 28, 2011 | 1996 Volvo 850
What is the gas oil mixture for a homelite ut20721 trimmer
Try a 50:1 mixture first if that is too rich,as in white smoke comes from the exhaust,then use a 30:1 mix.
Thank you for using Fix Ya.
Jun 03, 2011 | Homelite Mighty Lite Lawn Trimmer
Having problems starting Makita strimmer. There is quite a lot of smoke coming out and then it stops. Have looked at spark plug -clean, and cleaned air filter. Could the problem be the petrol and oil mix.
Use 50:1 gas/oil with a GOOD QUALITY 2-cycle low-ash synthetic oil.
Remove the muffler and check the spark arrestor isn't partially blocked.
With a clear muffler, and the mix as described, there will be hardly any smoke at all.
May 09, 2010 | Black & Decker String Trimmer Cordless 12"...
My trimmer tb 4 cycle smoke like 18 wheeler what my be a wrong wit it
You may have too much oil in the crankcase. You also may have broken piston rings. I would check the oil first. It could also be a carb problem. You just have to look at each possibility and eliminate them. ..Lee
Nov 09, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Gas/oil mix
Most trimmers are using a 50:1 mix. 2.6oz/gal or 6.4oz/2.5gal. A 4oz/Gal is a 32:1 mix which way too oily and you will have problems of excessive smoke, oil leaking out muffler, carbon buildup causing sticking piston ring or a clogged spark arrestor.
Aug 14, 2009 | Homelite Mighty Lite Lawn Trimmer
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
1,489 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
