Question about Bosch Integra® 500 SHX46A0 Dishwasher
Bosch dishwasher runs w/door open. Wont stop pumping water out
My Bosch dishwasher runs with door open. Our sink backed up into it and since then it has kept pumping regarless if door is open or closed. It will however turn off.
That was exactly my issue-I've tilted it 45d, emptied the tray and it works!
Posted on Apr 03, 2016
  • 213 Answers
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Posted on Nov 20, 2007
Rotu
  • 175 Answers
SOURCE: Bosch dishwasher SHU9922UC
Sounds like you already know how to fix it. The inlet valve is only held closed by water pressure...if you have low water pressure it could be causing this. Its more likely just a bad fill valve though. The water inlet valve is accessed by removinf the lower kickplate and the sheild behind that. Then all you have to do is remove the water line from the valve, remove the 2 screws holding it and pull it out far enough to disconnect the 2(possibly 3) wires and the fill hose. Make sure to mark where your wires go, if you hook it up wrong it could continue to fill and overflow. Hope this helps!
Posted on Feb 02, 2007
SOURCE: Neff dishwasher continuously attempting to pump out water
I had this problem too, I found a brilliant solution on a website, that worked, just put some towels on the floor and tip the dishwasher towards you, let the water run out and it will work again.............brilliant !!!!!
Posted on May 10, 2008
  • 205 Answers
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Posted on Jul 21, 2009
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
Bosch shv46c03uc
I would check the latch on the door..When you shut the door it makes contact telling the washer it's closed
Aug 17, 2013 | Dishwashers
My Bosch dishwasher has had a problem since we had it installed. It smells like garbage after sitting for a few hours. This problem is there whether it has been run or not. Water is always standing in...
Was the drain tube that hooks into the sink drain passed over the partition between the sink area and washer area or through a low-level hole. If through a low-level hole, try rerouting the tube over the partition. This forms a 'trap area' to isolate the sink drain from the washer pump area. Hope this helps!
Sep 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Bosch dishwasher
I had this same problem and in addition as it ran water dripped out the bottom while the dishwasher was running just before the tap light came out. Check the outlet hose is not blocked. Ours was blocked at the T junction where it met the sink outlet. Once the blockage was cleared we hit another problem - the pump kept trying to drain - even when the door was open. Found an excellent solution to that on this site. It had occured as the previous problem had casued the flood switch to be triggered. We had to tile the sihwasher back 45 degrees to fix it. Now its workig fine again.
Jul 10, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I have an older Bosch dishwasher I just hooked up in my condo. WHen a cycle is done there is no water is located at the bottom of the inside of the dishwasher, yet 2 days later water will drip on the floor...
when you empty you sink, some of the water is going down the drain hose of the dishwasher. take the drain hose up as far as possible in a swan neck
Jun 18, 2008 | Dishwashers
Dishwasher running with door open
most dishwashers will stick on pump if there is water in he base of the dishwasher . If you tilt the washer back only about 45 degs and water runs out of the back at the bottom the you have a leak but it could come from any where. But when there is no water in the base then your washer should start to work again until it fills back up
Dec 11, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Integra® 500 SHX46A0 Dishwasher Logo
3,373 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
