Question about Nikon Coolscan IV ED Film Scanner
Which air filter for GE Spacemaker JVM 1540 over-the-range m/wave
I purchased a GE Spacemaker over-the-range microwave, model JVM1540 at Lowe's. If I had a charcoal filter that came with the microwave, it would be easy to find the right replacement charcoal filter; but it didn't come with one. The microwave is non-vented, by the way. The JX81A charcoal filter (which is what Lowe's told me to purchase) doesn't seem to fit. Apparently, there's also a JX81C, and JX81D charcoal filter out there, but I don't just randomly want to purchase air filters. Help!
  • 4 Answers
The GE spec sheets for what is the right charcoal filter are incorrect. You will never find the right one. I have this same microwave and had same problem. I called a local appliance company and they gave me Part No. WB06X10359 and when I googled this part it was not the right dimensions. I finally found the perfect solution. Go to www.rangehoodsfilter.com (Filter Factory-TTN Inc.) and they are customing making the filter for me. I spoke to Dave this morning from Filter Facotry and he's making me one with the following dimensions - 5 7/8" x 13 1/4" x 1/4". The cost is $16.95. If this fits I will order more. The more you order, the cost per unit goes down.
Posted on Jul 19, 2009
1540 no turn no heat
There is a fuse and it may be some other things.But if you don't feel good about doing this kind of repair, I would have it serviced.
Jun 18, 2014 | GE Spacemaker JVM1540 Microwave Oven
The GE Spacemaker Microwave Oven model JVM1540 noise
The problem is more than likely the magnetron when it is running.
Mar 13, 2012 | GE Spacemaker JVM1540 Microwave Oven
My jvm 1540 will not heat. any advice?
Hi
Thanks for using FixYa. Microwave not heating properly is caused by a power relay going bad, cold solder joint on the board and/or magnetron (this is only if it makes a loud hum/buzz sound). Also the door hooks and the door-release button should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 31, 2010 | GE Spacemaker JVM1540 Microwave Oven
Where do you install the charcoal filter on spacemaker microwave oven model # jvm1540
remove the two and 3 maybe in the air grill at top of oven . behind inthe center is the filter . ( very pricey // about 60.00 / the make sure it seated properly so the air flow is through filter .. replace front grill and your done .. ****
Jan 09, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE 1540 handle...bottom fastener is broken. How
remove w putty knife the inter face. you can see the screws at this point ,. just remove screws and reinstall handle . pop interface back in **** . you can get a brake down of how this fits on sears web sight . **** / hope this helps ( it;'s not a hard job /time 1/2 hr / mm .
Dec 22, 2009 | GE Spacemaker JVM1540 Microwave Oven
Microwave Oven has no power.
yeah open the microwave, and you will see a fuse usually located on the top area. the is also a fuse around the back of the panel area.
Jul 02, 2009 | Microwave Ovens
GE microwave lights and fan do not work
If one of the surface light bulbs burnt out it may have shorted out the control board. Take the control board out and look for a burnt spot on the board. It may be able to be repaired with a drop of solder or solder in a jumper wire. Or you can purchase a new board, which may cost more than you want to put into the microwave.
Jun 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Nikon Coolscan IV ED Film Scanner Logo
342 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
