Question about Qtronix Scorpius 98N Plus Keyboard
Volume control My computer's been acting kind of funny to start with lately, it kept shutting itself down and when it started working again it didn't go back to normal... it won't let me access my volume control on the screen so earlier I was listening to some music and I wanted to turn it up. I tried using what appears to be the volume control buttons on the keyboard itself, but somehow the + button mutes, and I don't know which one I pressed but I've completely muted the sound on my computer and no matter which volume button I try pressing, it's not coming back... I really love my music so if anyone can help me out with this problem it'd be much appreciated! Thanks!
  • 3 Answers
Try to boot into Safe Mode (windows 7: press F8 on boot, or Win10: start: type msconfig, enter, then boot tab: [x] Safe boot, press enter). It will be more successful more often in Safe Mode, but whether you can get into Safe Mode or not, click Start, type System Restore, press enter. (You may have to go to System Properties: System Protection tab, then System Restore.) When you restore to a previous restore point, you may find the weirdness to go away. If your problems are due to malware having been installed, you may have to choose restore points further and further back in your restore point history until you get back to before the malware, then the badness goes away. System Restore does not affect your data, only the Windows files.
Posted on Apr 03, 2017
1997 Plymouth Breeze Engine keeps shutting off.
You need to do an OBD2 engine control module fault code test to see if the fault is recorded in the memory of the computer control module. Autozone and others do this testing for free.
Jun 24, 2017 | 1997 Plymouth Grand Voyager
User mode window (for adjusting the contrast, brightness etc) appears again again automatically.
First off... I would Re-Start your computer...OR...Shut down manually... to see if this fixes your problem. It's possible your computer didn't accept the changed setting? But...what you are experiencing is a Corrupt File, which will need to be removed!
Not sure exactly what you did? Where you trying to adjust the contrast, brightness, etc,.?
If you went through your Desktop to adjust these settings, always make sure you select APPLY and OK..
If you went through your System to Change your Resloution, you may have a Conflict with your chipset or even Malfunctioned it?
If re-starting your computer didn't fix your problem, than shut your computer down again!
Upon,..Re-booting...This time hold the Control Key down, so you can get into SAFE MODE!
I would then do a SYSTEM RESTORE under (SAFE MODE) and Restore your computer back to an earlier period that your computer was working correctly! Even, if you cleared the problem on the first step provided! Just type in the search box in your Control Panel System Restore! Or you can type in at the START Button...System Restore!
Also, while in SAFE Mode...go to your Device Drivers in your Device Manager and check for any setting that have a yellow symbol next to them...Click on each one and Update the Drivers!
Always, make Re-Start your computer after doing any changes...!
If you need further assistance, please don't hesistate to reply back to me! I'll be happy to help you!
Kind Regards!
Sep 10, 2011 | Dell E773C 17" CRT Monitor
Hi I have Prima lv 3228p tv and there is no volume it was working fine yesterday andtoday no volume
prima lv-3228p lcd tv-after 15 mins of play the screen goes funny and there is still volume but the remote will not function. you cannot even shut the unit off, only by disconnecting the power supply. If you wait 15 -20 mins and plug the unit back in it will work for approx 15 mins again- then it will start acting up again?/
Jan 13, 2011 | Televison & Video
Jeep not running right!
what i do when i see cars that act like that is check fuel pressurse when the problem is acting up also check the spark to see if it is present at the time of the no start also when the check engine light comes on set up with a shop to check forr codes when the light comes on dont shut it off until the scanner can rread the codes. also that veh is equiped with a auto shut down relay system what is does is if a crank shatf sensor starts to go astray it can send the computer into shutdown mode also the o2 heaters can short out and that will send it into shut down mode also when it goes to shut down you will see it on a scan tool that the relay is shutting down also look at the grounds for the cruise control its usaully not the asd relay uaslly a system connected to it that shuts it down. hope this helps thunderboltz
May 27, 2010 | 2001 Jeep Grand Cherokee
Face gets stuck & can't use controls
i was told by manufacturer that is called a cable ribbon and cost about $30.00 thru dual electronics.
Sep 04, 2008 | Dual XD7600 CD Player
97 Toyota camry
Unfortunately diesel leaves a residue in the lines and on the injectors.
There is only one cure for this, take out the injectors and get them serviced and flush all the fuel lines out with clean gasoline.
Aug 05, 2008 | 1997 Toyota Camry
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
Qtronix Scorpius 98N Plus Keyboard Logo
50 people viewed this question
Top Qtronix Computers & Internet Experts
David Payne
David Payne
Are you a Qtronix Computer and Internet Expert? Answer questions, earn points and help others
