Question about Sharp AL-1655CS Copier
'H' error code
Sharp AR-1625 is displaying 'H' - no buttons function.
Thanks for your help.
  • Anonymous Nov 08, 2007
    H symbol flashes
  • 30 Answers
Sharp's diagnostics use the letter "H" t designate a problem with the fuser, that is the part of the mahine that heats up and maintains a set temperature. The "H" is usually followed but a number, either 3 or 4 to indicate whether the temperature is either too high or too low. In many cases, there is a temperature fuse that will blow out and render the heater powerless. It will have to be replaced by a technician who will then run a reset code to bring things back to a normal condition. Sorry I couldn't be more help.
Aloha,
Bill Monroe
Posted on Oct 21, 2007
Error code sc 194 in 1015 ricoh means
Posted on Nov 09, 2007
  • varthman Nov 09, 2007
    error code sc 390 in ricoh 2015
Sorry to say the guru is right. the only problem is that it is easier to replace the entire unit then to rebuild it you will have to go through the menu to find maintance and reset the code to default. After you replace the part it will resume factory settings.
Posted on Oct 22, 2007
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Sharp AR-M208N with OFH4-00 error code
Hello sir; This code require simulation to reset the procedure as follow; press "#", "interupt", "clear", "interupt", then enter 14 press start. turn power off and back on, then all set.
Sep 27, 2009 | Sharp AR-M208N Copier
Ar-160 display says "check panel" no more codes or functionality
tis problem is some of panel button is short i mean it is lock please open your machine panel board and service it . then solve your problem
Aug 02, 2009 | Sharp AR 201 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Sharp ar-5320e error code U2
please press these buttons in order #, interrupt,C , interrupt.
when display goes off enter 14 then start button it is ok
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Need some help
to get rid of this error pls enter simulation mode by doing the following steps:-
press # , interrupt , C, interrupt consequently . when the display is off, enter NO. 14 and press start button
Dec 26, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1655CS Copier Logo
290 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
