I have a frigidaire front load washer, and it stopped in the middle of a cycle , i can see the water about 1/2 way on the glass. It just sits there.i can un plug it and restart it and it will come on for 1 or 2 seconds and just sit there again. ??? God Bless and thanks !
    Top Expert:
  • Washing Mach... Master
  • 75,822 Answers
U are going to have to have the main circuit board replaced to repair this timer problem, go to this link for trepair and parts information.
http://www.repairclinic.com/0047_11.asp
Posted on May 25, 2009
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer won't drain
hi,
The timer went bad. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure
Mar 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Middle of cycle and won't start, just hums
You have a drain problem check the hose going to the pump.I bet u find a sock or such in it.
Nov 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Washer stopped dead in the middle of cycle
CHECK ALSO the sensor switch underneath where the door close , you gonna need a tester for this task ,hope this helps AJ
May 05, 2008 | Hotpoint WMA13 Front Load Washer
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Shaking
We have finally resolved our problem thanks to annetipu's note about someone mentioning a rod or pin that had to be removed. On the Frigidaire website, you will find the following:
14. Vibrating sounds. Tumble action washers: Shipping bolts or braces are still in the washer.
Remove 3 shipping bolts, 3 yellow spacers and 3 metal "P" clamps from the back of the washer. Remove the access panel from the front of the unit and remove 2 yellow shipping braces and large Styrofoam shipping block. Replace the access panel.
This solved our problem. Washer is wonderful now!
Sep 22, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
