Question about Dell 948 All-In-One InkJet Printer
Paperjam when paper doesn't even go through the printer
I'm trying to print a document using my Dell 948 Inkjet printer, but whenever i do, the paper doesn't go through and it says that there is a paper jam. I can't get it to work. Can anyone help me fix this? If i have to open up the printer, can u give me pics to show me exactly what to do?
I guess there might be a torn paper stuck up inside but'll have to cnfm only on opening the cover
Posted on May 26, 2009
Dell 948 Printer Problem
Try uninstalling the printer software from the computer then reinstall.
Dec 10, 2013 | Dell 948 All-In-One InkJet Printer
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
While attempting print a document, Dell All-In-One 948 InkJet Printer printed a document that was not opened. How can that happen? I haven't tried anything to fix it because I don't know where to...
Most likely, this document was already in the print queue and never got printed. If that's the case, open notepad, enter the following commands : net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Save this to your desktop as DeletePrintJob.cmd, run as administrator (right click on it, select run as administrator), then reboot your pc/powercycle the printer. This should resolve your issue. If not, please let me know.
Mar 05, 2011 | Dell 948 All-In-One InkJet Printer
Dell 948 printer will not delete a document
try putting a sheet of paper on the printer and hit the print button..
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
Dell 948 printer. Black(2 inch) Vertical lines when I print
You need to check the glass for any white-out or other smears that don't belong, if the glass is clean then the scan assembly has elements that are burned out which will cause dark streaks.
Jun 30, 2009 | Dell 948 All-In-One InkJet Printer
Every time I turn on my printer, a Dell 948, it prints a page
Hi
We have 30+ printers... which we use for testing empty inkjet cartridges prior to refilling with ink. Basically we inject a little Magic Inkjet Flush directly into the dried print head which allows us to unclog them. Then we soak them overnight on Magic Pillows which gives just enough to do a PRINT TEST next day.
As some of our printers always try the alignment test here´s what we do...
1. Pull paper stack slightly away from printer, when it tries to print it thinks it is out of paper and should offer a cancel print option.
2. Alternatively if you print daily? Try leaving your printer power on... Some do alignments every time you power up... so dont switch off (they use very little power in standby.)
3. When exchanging inks like HP immediately switch off printer which cancels the print test. Then just switch on again.
4. Reinserting your printed sheets each time will save paper if not ink.
Good Luck!
Tinteiros (Ebay)
Mar 22, 2009 | Dell 948 All-In-One InkJet Printer
Dell 948 printer printing not finishing print jobs
Your printer loose documents:try to reset it ,unplug for an hour.
Or you might have interferences on your wireless :DECT phone, cell phone, or even an electric device who doesn't work propely, like tv, stove, speakers many things can parasites your connection...
If nothing does your printer as issues, think replacement...
cheers
Dec 19, 2008 | Dell 948 All-In-One InkJet Printer
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
PAPERJAM
hey gramma try to do one thing before even going for test page , open the panel and cover where u will be able to see the catridge ccarriers, try to blow air, or after opening the cover titlt the print and shake it gently sometimes due to some dust particle the paper jam happens
Feb 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Dell 948 All-In-One InkJet Printer Logo
195 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
