Question about Hayward Pool Products Volute, Pump
Non continuous pumping
The pump primes itself OK, fills the reservoir, then kind of burps, empties about half the water, then primes itself OK again. This repeats itself continually. But it never worked liked that before.
    Problem Solver:
  • 14 Answers
Sounds like it's sucking in air from somewhere.
Posted on Jun 14, 2009
The water does not go through my espresso maker have tried to clean its not working
If you tried to clean it (descale) and did proper and still does not work, this is most likely a pump vapor lock kind of issue. This can be cause from a small blockage to cause the vapor lock for the pump to work to pump the water, or just a vapor lock to get that water to pump; MOST THE TIME IT IS A PRIMING ISSUE. kind of like bleeding the breaks on a car. Read below and follow steps.
You can
hold your finger over the white tube in the top of the reservoir to place more
pressure on the water to flow through the needle and expel the debris from the tubing.
Take a can of compressed air like you would use to clean your computer and blow air through the tube(s) in the reservoir and also the needle(s) to clear dirt debris and water from the machine. This process may make a mess so be sure to have the machine is a place where the mess can be cleaned up easily. Some have even used a large tire type air compressor out of desperation, and report that it does work. I would use great care with this method and shoot the air in very short bursts.
      Often the pump gets air in it and does not prime correctly. It will then only pump a little water. To fix this you may need to get rough with the machine. Slamming the reservoir onto the machine will sometimes work, The shake rattle and roll method also will have the desired affect sometimes. Some have turn the machine upside down over the sink, have slapped the sides of the machine, or even shake the machine to get the air out of the lines.
      Once you do get the pump to prime properly, you can keep the pump from getting more air by making sure to fill the reservoir before it gets empty by using a pitcher to fill the tank instead of removing it and filling it.
      With some Krups, the bottom needle does not pierce the bottom of the cup if you simply place the Krups into the holder and then close the top. Extra effort may be needed to make sure that the K-cup gets seated properly so that the water can flow through the Krups easily. If you have water still in the K-cup when you remove it after brewing, you are having this problem.Bottom Line I believe most your problem is going to making sure tubes are clean and priming it, even have have to get a little rough and shake machine to get the pump working as air lock gets out. Let me know if this worked for you. Takes some patience, but should get to working with some time Thank you, Mike from fixya
Sep 15, 2011 | Krups Coffee Makers & Espresso Machines
I have an Asralpool self priming pump ref 20601 / serial 094585V It turns on ok but does not seem to be pumping. If left on for 10/15 minutes the pump is obviously getting hot as the water in the...
Is there a place to prime the pump? Self priming doesn't necessarily mean it doesn't need help. If there is no place tp put water in the pump, consider disconnecting the suction hose and fill ith with water, hold the hose up toward the motor to get the most water in you can, then reattach it to the pool and try again.
Aug 12, 2010 | Pool & Spa
10000 gal pump
as with any pool pump they have to prime themselves,, close up the unit as it was before,, and turn it on,, remember that water is also the cooling agent for these pumps, check to see that its pumping water as before,, ( yours may even have a place to prime it,, Look for an easy access prime hole in the pump unit itself )
Aug 02, 2010 | Intex 1000 Gallon Easy Set Swimming Pool...
Water fills the pump basket area and empties once full
This could very well be low water, it should be half way up the tile or the skimmer throught. Also check your skimmer weir door. If it get's stuck in the up position it will do the same thing. To be sure start the pump then watch the water in the skimmer. If it sucks dry then it is one of these things.
May 15, 2010 | Jacuzzi 3/4 Hp Cygnet Pump
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
I have a portable air conditioner and the water condensation tank fills in about 4 hours of constant use. Is there any kind of portable water tank that I could attach to my unit that would allow me to...
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
Jun 11, 2009 | GE APN10AA Portable Air Conditioner
New Keurig B140 will not pump or prime
On the water reservoir there is a little black disk, a magnet, I think... If that is not against the machine it will display the prime error. Empty the water from the reservoir and tilt it so that the disk is against the machine. Place the reservoir empty back on the machine and fill it with water carefully as not to move the disk. When the water level gets to the correct position, the prime error will go away.
Oct 30, 2008 | Keurig Special Edition B60 Coffee Maker
CANNOT PRIME PUMP AFTER DESCALING - therefore CANNOT MAKE COFFEE
first vinegar is not strong enought proper descaler for expresso machine and in our water container the hole in the bottom put water in the tank with a hoseor turkey juicer our anything you got push water in hole you need to pressurize to forse the pummp to trim itself hope it help fixya pierre
Jul 24, 2008 | Keurig Elite B40 Coffee Maker
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Hayward Pool Products Volute, Pump Logo
123 people viewed this question
Top Hayward Pool Products Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Hayward Pool Products Garden Expert? Answer questions, earn points and help others
