Question about Poulan Garden
After rebuild only runs on half choke.Adjusting screw doesn't help
I have a CIU-W4A Zama carbuerator on a Poulan weed eater Featherlite model.Installed RB-73 reuild kit.Will only run on half choke for awhile.No choke position it shuts off.Help!
  • Jim Mitchell
    Jim Mitchell May 27, 2009
    Thanks #1 taper.Changed screen.mitchjl_1692
  • Anonymous Mar 21, 2014
    i remove the muffler there was no carbon inside
  • 1,040 Answers
The rebuild you did is correct, but did you clean the small ports in the carb.? I use a Den Tek Brush (used for cleaning teeth). They work great for this job. You may also want to check the small screen in the carb. The smallest of particles can cause this problem.
Jim
Posted on May 26, 2009
  • Jim Parker
    Jim Parker May 28, 2009
    Thanks for the rating mitchjl. If you have any drywall questions, or know someone who does, put them to "Tool-Building & Power-Hand Tools" category at FixYa.com.
    Thanks Again,
    Jim
Blower only runs with full choke. When I switch to half choke, it dies and won't start.
it may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
failing that it needs a carb kit.... this is a serviceable item changed regularly.
Mar 14, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Trying to get my Poulan BVM 200 to start consistently. Need a service manual or help with the carb adjustment screws. Does anyone have a manual or a good description on how to do a carb adjustment?
These machines are typically at the bottom of the food chain when it comes to quality control and workmanship. Many are sold, but many turn to junk. You probably have the splined-head screws typical of a lot of these carbs..a Zama possibly. They have the carb adjusting tool for these for sale on Ebay. There are other home-made ways to loosen and adjust these screws too. Consistent starting probably won't be achieved till after you install a carb diaghram or rebuild kit and replace any old fuel lines and filter. Some of these engines run great and some are lemons.
Aug 13, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
POULAN FEATHERLITE LEAF BLOWER WILL ONLY RUN AT 1/2 CHOKE
Sounds like you will need to clean your carburetor, or rebuild it. Could be some debris in the jets of the carburetor. If the blower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank and not run at full speed. Hint: When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Jan 05, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My Poulan featherlite weed eater will not run on no choke
yes you could have
anytime you have to run half choke or choke to get to run you have a lean condition and not enough fuel.
you could also have a stuck ring on the piston which is very common and this requires dismantleing engine to access,also scuffed piston and etched cylinder wall.
if you have a compression guage you can screw into the spark plug hole and hold throttle open and pull the rope 5 0r 6 times like your trying to start it your final reading should be 70 psi or above if its below 70psi you may have the above mentioned
also check the tightness of the 2 head bolts allen type or torx type sometime they loosen and the gasket between the cylinder head and crankcase blows out
just some things to check hope this helps some
Jun 07, 2009 | Poulan Garden
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed eater featherlite primer bulb won't fill with gas. it does not appear to be broken and fuel line is clear and filter is new. any ideas?
Hello
From your Description and Depending on the OEM (Zama or Walbro) of the Carburetor it Sounds like a Bad Fuel Filter or the Primer Check Valve has Stuck and the Carburetor Requires Soaking and Cleaning.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.poulanpro.com/poulanpro/indexAction.do?id=default and Select Order Parts and Accessories. On this Page Select Illustrated Parts List from the Menu on the Left. Now Select the Manufacturer (Poulan/Weed Eater) and Enter the Model Numbers in the Boxes at the Lower Left of the Page.
I Require the OEM (Walbro, Zama, ect) and the Model Numbers Off the Carburetor. With these I can Locate a Breakdown of the Carburetor and Better Assist you.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the gas/oil mixture ratio for the featherlite gas weedeater?
its a 40:1 ratio. remember to never tap the tap-n-go too hard or it will bend the shaft, and make the head hot to the touch, and eventually will melt the inside. And always keep fuel stabilizer in the gas, because if you dont, especially in winter and fall, it will clog the carb so you have to keep pumping the throttle to keep it running and you have to run it on half choke all the time
good luck!
,devin
Apr 25, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
707 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
