Question about GE (PSS26MSRSS) Side by Side Refrigerator
Mother boad replacemet
Model # gss22jetacc ge ref s#am20845 my understanding is on this model when you replace the mother board that there are some wiring change to be made there is no instructions in the new mother board box
  • kdonann May 25, 2009
    ge ref m#gss22jetacc s#am20845 mother board replace ment change all thermistors mother board no freezes every thing in ref sec is there any chges to wiring on mother board or what is the problem
    Novelist:
  • 151 Answers
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable.
Posted on May 26, 2009
  • GE Master
  • 19,396 Answers
As far as I know, you do not need to change any wiring.
Just undo the three nuts around the board that you find at the back of the unit. Remove the input wires and push in the plastic tabs holding the board. Then fit the new board and push until you hear the tabs snapping in place. Re-install the wires as they where originally and put the cover back on.
Also make sure that the coils are totally defrosted before starting up the refrigerator after changing the board.
See diagram below:
Posted on May 25, 2009
  • Ginko
    Ginko May 25, 2009
    I am telling you that you can fit the prugs in one only possible way, and that there is no wiring modification that you need to do, just plug the connector on their respective sockets , you can't go wrong.
    Read testimonials here.
    Please change the negative rating given .
    Thanks.
Ref area temp stay at 12C. Ventilation dont work. New bulb light dont work. Front door indicator for ref. temp doesnot work. Freezer work at -11C
You didn't list a make and model but I have seen similar problems in GE refrigerators that have a computer mother board in them. The board gets damaged by possible power surges and since it controls almost everything you get strange operations and temps. Most mother boards and mounted on the back outside of the cabinet under a cover plate about 8 by 12 inches with screws all around the edge.
May 07, 2015 | Refrigerators
Ge refridgerator model gh405499
From what I know of ge, ice makers are independent. Mother board has no control over I'm. How old is this fridge. Some of the newer ge are made by Samsung and are control.
Nov 03, 2012 | Refrigerators
GE GSS25KGSAWW side by side refrigerator not cooling properly. We pulled the defrost heater out after thawing the freezer and the glass tube is discolored but I get continuity reading across it. Should I...
Since the heater has continuity it is good and does not need to be replaced, the other parts that can make a ref. not defrost are the defrost thermostat or the defrost control (mother) board.
To check the defrost thermostat it must be checked when cold,when cold it should have continuity on it. The defrost thermostat is in the freezer clipped to the TOP of the evaperator coil usually on the right side...this is what it looks likeoldtech2332_122.jpg
If the defrost thermostat has no continuity when cold it is bad and thusly the problem...if it is good and has continuity and already having determined the defrost heater is good..the problem is going to be the motherboard since a part of it is the defrost control.it is the back of the ref.on the left.
The part numbers are
DEFROST THERMOSTAT...... WR50X10068
MOTHER BOARD..... WR55X10942
Sep 23, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have asus mother boad p5s800-vm/s. but i dont have mother boad drivers.pls sent me link to download. Thanks
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select drivers that matchesyour Windows operating system. Please click on this link to their WEB supportsite : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Apr 17, 2011 | ASUS P5S800-VM Motherboard
GE MODEL# GSL22JFPH BS SERIAL# DH212339 side by side The refer will cool for about a week then frost builds up in the back of the freezer behind the panel, will defrost with hair dryer , will get...
the defrost timer is built into the mother board / but before replacing it / I would ck the heater's and if bad replace them there is a newer style and also replace the defrost terminator . and if you still have the problem then repl the main board .. mm
Sep 23, 2010 | Refrigerators
I have a GE side by side ref. model # GSS22JFMC WW that is not cooling. A few months ago I replaced the defrosting element. It is not freezing up but for some reason it sometimes stops cooling. I can turn...
First this refrigerator has very low consumer rating. They are plagued with problems with very poor company backing. But without be able to diagnosis the problem in person I would say it's the mother board. And you may find that GE has a new updated board for your appliance. I would go to Amazon.com and search for your motherboard for your refrigerator and read the reviews. Some people leave some great idea. Plus it you bought this refrigerator brand new you can fight with GE to send you a new board.
Oct 29, 2017 | GE GSS22JF Side by Side Refrigerator
MOTHER BOAD
You can upgrade your BIOS from www.elitegroup.com
itJSN
Aug 30, 2008 | Intel Motherboard
Compaq note book nx9030 mother board driver
You may download all the latest drivers from the following link.
Driver according to the make/model/os
Regards,
Sammy
Jul 10, 2008 | HP Compaq nx9030 Notebook
Charging problem
i really don't understand? make you're statements a little clearer
Jan 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
GE (PSS26MSRSS) Side by Side Refrigerator Logo
63 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
