Question about E-Machines eMachines Desktop PC
1 long beep, no bootup. I just get a test screen.
I power up my pc, and I get 1 long beep. But it will not boot up.
    President:
  • 1,996 Answers
The beep you hear is known as a bios beep code. It indicates the failure to post and can be used to determine what kind of error is preventing your startup, but you need to know what kind of bios or motherboard you have installed. You should be able to look this up at the eMachines support site, but using your model number to find the original specifications of the system.
Then use this article to troubleshoot the error. Also helpful may be this article and this site.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 25, 2009
  • 85 Answers
1 long beep = error code. 1 tiny beep equals POST
Do you get picture?
Depending on your bios that can mean different things. I'll take a crack at it cause most of times its 1 of 2 things. Either your video card is not seated right or your RAM is bad or not seated right.
Intel pentium - booting up ok, but nothing shows on screen. Pressed F12 came up with error message error setting up the MD3 over power button. Also, unable to locate media direct BIOS table.
If your computer is showing nothing on screen it is not booting up OK. Are there any beep codes being given during bootup? One single beep at the end of the POST sequence is OK, anything more means some kind of hardware error found during bootup. Media Direct 3 is a Dell product that has caused a number of problems on its computers. See Dell MediaDirect . Your option may be limited to contacting Dell support.
Jan 29, 2017 | Intel Computers & Internet
ET183105 PC Desktop black screen on bootup
do you get any beeps or ... you know what, describe what happens exactly.
May 19, 2012 | eMachines ET183105 PC Desktop
Four beeps pc will not bootup
Hi John Jones:
1 long, 3 short beep means >>> Bad video RAM or video card not present. You need to check your RAM. Remove RAM and insert again.
If beeps are of high frequency then CPU is overheated, check you CPU fan.
Hope it works for you.
Dec 25, 2011 | Dell Computers & Internet
Everytime i boot my pc,it beeps 2x,then black screen,so i have to reboot again
The beeping is caused by your computers POST( Power On Self Test - learn something new everyday! ;) )
Find your motherboard manual, and have a look in it for beep codes, or error codes. The number of beeps will let you know what kind of problem you're dealing with.
If all is well in POST, your computer should only beep once, and continue.
Can you get into BIOS at all, or does it just show you your videocard info on bootup, then black screen?
May 27, 2011 | Microsoft Windows XP Professional
My dv6-1247 cl when i turn on the power it beep 8 times and the screen does not come on help
Yu will need to determine which BIOS you have a see below
The computer beeps several times
If you hear several beeps from the PC speaker, it means that the computer failed its power-on self test (POST) because a problem was detected. The POST is a procedure that tests several components such as power, BIOS, CPU, memory, and video. Only if all those tests pass, the computer will then allow the operating system to load. But if one or more of these tests fail, beeps indicate a problem and the boot process is halted. These errors are a little more difficult to troubleshoot.
To diagnose the problem, listen to the beeps carefully and write down the sequence. Is it one long beep? Is it several short beeps? How many? Once you have the beep sequence documented, you need to find out what it means. What BIOS do you have? When you first turn on the PC, look at the top of the first screen to find out. Common BIOS types are Award, Phoenix, and AMI.
Award:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beeps Most likely a RAM problemYou can find more detailed information about Award error messages on Award's web site.
Phoenix:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information 1-2-2-3 BIOS ROM Checksum 1-3-1-1 Test DRAM Refresh 1-3-1-3 Test Keyboard Controller 1-3-4-1 RAM Failure 1-3-4-3 RAM Failure 2-1-2-3 Check ROM Copyright Notice 2-2-3-1 Test for unexpected interrupts 1-3-4-3 RAM FailureYou can find more detailed information about Phoenix error messages on Phoenix's web site.
AMI:
1 beep Refresh failure 2 beeps Parity error 3 beeps Base 64K memory failure 4 beeps Timer not operational 5 beeps Processor error 6 beeps 8042 - gate A20 failure 7 beeps Processor exception interrupt error 8 beeps Display memory read/write failure 9 beeps ROM checksum error 10 beeps CMOS shutdown register read/write error 11 beeps Cache memory badYou can find more detailed information about AMI error messages on AMI's web site.
If you get beep errors, you should try to think what happened right before they started. Did you add a new piece of hardware? If so, it might be faulty or not installed right. Remove it, then try again. If everything is fine without the hardware, try to reinstall and configure the hardware again. If that does not help, try exchanging it and see if that corrects the problem. If the error persists, narrow it down systematically. Remove everything but the CPU, memory, keyboard, and video card, then boot again. Does the error still occur? If not, then add one piece of hardware and try again. Repeat until one new component causes the error and you now know who the culprit is. If yes, then reseat your CPU, memory and video card and try again. If the error still happens, try replacing the CPU, video card and memory one by one to see if one of them is the troublemaker. If that does not help, you could have a bad motherboard. Check the motherboard carefully for any signs of damage. Also check for shorts, a metallic object could have found its way onto the motherboard, or the motherboard is not installed correctly and touches the case somewhere.
Page 1: Computer boot problems
Page 2: This page
Page 3: System hanging after POST
Page 4: POST running OK but Windows not starting
Good luck
Please rate FIXYA
Thanks
Apr 02, 2011 | Computers & Internet
Booting problem
See 1. hard drive in BIOS. 2. Bootup sequence in BIOS If it`s ok try to reinstall Windows
Apr 10, 2010 | Lenovo 3000 Y410 Laptop
Makes loud alarm sound when it is booting up and scrolls up on its own
Hello there lmitche4.
Here's your geek-steer ...
Is the sound you're describing a "beep"/tone? In all likelihood it's yes. At bootup, beeps codes occur if the motherboad/BIOS encounters any error during the POST (Power-On-Self-Test) sequence. Unless just one single beep (all is well), these beeps alert you about, and to the nature of, a problem in need investative/corrective actions on your part.
Refer here and/or here for an index of beep-codes, then determine which beep sequence you're hearing. You'll first need to know which BIOS you have installed. You can determine this quite easily by hitting the "Pause/Break" key on your keyboard in order to freeze the screen at the initial part of bootup when this info is typically displayed.
Good luck, and please do post back to ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 10, 2009 | Acer Aspire One PC Notebook
One beep at startup - System does not bootup
You have what sounds like a RAM problem. Try known good RAM as a test. If it still fails, remove add on cards except video. Make sure that video card works. If it still fails to boot. Replace motherboard.
Jun 01, 2009 | E-Machines eMachines Desktop PC
I have 2 GX520's that are buzzing when trying to boot
If your computer beeps during start-up:
  1. Write down the beep code
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM read/write failure
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer failure
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
1-3
Video Memory test failure
1-3-1 through 2-4-4
Memory not being properly identified or used
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller test failure
3-3-1
NVRAM power loss
3-3-2
Invalid NVRAM configuration
3-3-4
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No timer tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-1
Memory failure above address 0FFFFh
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-2
Failure to decompress code to shadowed memory
4-4-3
Math-coprocessor test failure
4-4-4
Cache test failure
Apr 11, 2009 | Dell OptiPlex GX520 PC Desktop
Computer will not boot up. Screen remains blank after powering up. System emits two(2) beeps.
This is a memory failure problem.
Open the case and make sure the memory modules are seated in the sockets properly, make sure the computer is disconnected from the power source first.
Once checked plug it back in then switch on the pc.
It may bootup as normal, if it does not then you need to change the memory modules.
Aug 12, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
143 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
