Question about Toshiba TZ50V51 50" Rear Projection Television
Intermitant failure with blinking light
For a while now my tv will turn off and the red light above the power switch will start to blink, trying to turn it back on at this point does not work. Unpluging the tv for a min. usually fixed this problem for a while. But now the gaps of failure are getting shorter and shorter, help. Thanks Jon
Re: Intermitant failure with blinking light
I'm a little tired of slinteriors telling us to go to that site to order something. How do we fix it?
Posted on Jun 06, 2008
  • Toshiba Master
  • 8,617 Answers
Is your tv a Toshiba TZ50V51 ? If so, You can get the manual to trouble shoot your toshiba for 10.99 at the following link. It is called power supply and shutdown circuit trouble shooter. It covers your model number. It has step by step instructions to get your set up and running. It is located on the bottom of page 2 in the Toshiba section if your interested.They will also email it too you instantly, If you return to the site and leave your email address. This is a good manual. I have used it myself many times. Here is the link, If you're interested in it.
Posted on Jan 24, 2008
0 characters
3 Points
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Projection Televisions
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have a large projection toshiba tv. When I turn it on the red light indicator blinks but tv screen does not go on. Please help and let me know what I am doing wrong. Thank you.
one thing you may try first is disconecting the tv from ac outlet and plug back in ater 20-30 seconds, try to power back on. If nothing happens you're not doing anything wrong it might be that the tv needs circuit repair, the light blinks and you get sound indicateds a possible deflection board problem either horiz out transistor or surrounding circuit if you only get the blinking light no pix or sound could be also indicator of defl circuit failure or switching mode power supply acting up.hope this helps please let this site know if your question was answered.
Aug 22, 2009 | Toshiba Projection Televisions
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Projection Televisions
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba TZ50V51 50" Rear Projection Television Logo
109 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
