Question about Lexmark X3550 All-In-One Printer
Lexmark x4350 says scan request failed what do i do?
4 Suggested Answers
SOURCE: requesting scan -
I've had the same problem occasionally when re-installing. There are a couple of ways to solve this.
1- Right click properties on "my computer" (or open "system" in control panel). Bring up the Hardware tab. Click on "device manager" button, then scroll down to see if there are any devices with a yellow exclamation point. if one is "scan" then the windows did not yet install it. (This can happen if windows installed the print drivers automatically before you actually installed your printer driver. Remember that even if the printer is turned off, it will still be recognized by Windows unless you disconnect the usb cord). Solution: delete the highlighted button. Then restart your computer. If you have already run the dell installation disks, windows should recognize and install the software. Be sure to have your disk inserted in the cd drive when you restart. Otherwise:
2- use your dell installtion disks to uninstall, then re-install. Hope it helps. :)
Posted on Feb 17, 2011
SOURCE: Can the lexmark x4530 support airprint?
Yes but the eirthernet cable has to be plugged in
Posted on Aug 25, 2012
  • 7993 Answers
SOURCE: What is an ORC?
ORC is life form in the Lord of The Rings. What you want is OCR which stands for Optical Character Recognition. It is the software that converts a scanned document into a string of characters that you can edit to correct OCR errors.
To be able to scan to a computer the computer and the printer must be connected through a USB port or be part of the same network.
When you press the scan button, the printer tries to communicate with the computer and launch the scanning software installed on the computer.
Install the software that shipped with your printer, connect the computer and the printer. If everything is correctly connected and installed, the scanning software will open to receive the scanned document.
Posted on Oct 14, 2012
"Connection with Computer Failed" When I Try to Scan
If the primitive (as you call it) Windows Scan program is working then there is no problem with the machine. It can connect to the computer.
I suspect that the other (non primitive) scanning software is not configured correctly. It may be using a wrong driver. You may have installed some other device that is able to scan (such as a program that capture screens from calculators) and it has been set as default driver. Check the configuration of your scanning software.
Jan 23, 2014 | Lexmark OfficeEdge Pro5500 4-in-1 Inkjet...
What is an ORC?
Oct 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
Mar 02, 2012 | Lexmark X4530 InkJet Printer
I do not have the disk that enables me to scan and create PF files, what do I ndo?
The Lexmark OCR scan software that helps you scan your files to PDF is available in the installation disk only. Feel free to contact Lexmark technical support to request for the disk for your Lexmark X5650 printer. Thanks.
Oct 22, 2010 | Lexmark X5650 All-in-One InkJet Printer
I've lost my set up cd and although the printer and copyer work I cannot scan a document onto the computer.
Scanning a document to your computer may require the Lexmark OCR scan software which is only available in the installation disk. Try to contact Lexmark technical support to request for the installation disk. Thank you for choosing Lexmark.
Sep 15, 2010 | Lexmark X4650 InkJet Printer
Lexmark 5600 how can a I scan or make it a word document or pdf file
You will need the Lexmark OCR scan software to scan a document from the printer to your computer and save the file as PDF, word document, etc. The Lexmark OCR scan software is only available in the installation disk. If you don't have the disk or you lost it, contact Lexmark technical support to request for it. Thank you for choosing Lexmark.
Sep 14, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
All in one scanner does not appear, installed without CD
You can download the scan software from the Lexmark website. However, the Lexmark OCR scan software for scanning documents can only be installed using the installation cd. If you want, you can contact Lexmark Technical Support to request for it. Thanks.
Jul 21, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
SCANNING WITH LEZMARK X4450
I gave gotten it to retrieve the applications list by opening Lexmark Imaging Studio while it was searching, I AM however still unable to scan it connects to my comp I tell it to save as a file and it goes "Requesting Scan" then "Scan Request Failed"
Jul 13, 2008 | Lexmark X4550 InkJet Printer
Lexmark X3550 All-In-One Printer Logo
437 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
