Question about Toshiba Satellite A305-S6863 Laptop
Toshiba Satell T2080 Webcam(''Chicony USB 2.0 camera'')not working
The webcam on my laptop works about 1% - 2% of the time. 98% of the time it does not work. The laptop is brand new...less than a year old. I ran Driver Detective on the laptop and it tells me the driver for the camera is working and up to date. I have had this problem since day 1.
When I try to start the webcam it tells me any of the following messages: "the webcam is not connected, sorry, no webcam was found on your system" or that it is "blocked by another application."
I contacted Toshiba a couple of months after purchasing the laptop and told a lady about the problem. (I am no genius on computers, so I hope you keep this in mind when you correspond with me...layman's terms only please.) The woman had me go to different places on my laptop...looking back I have no idea where...she told me to check certain boxes or uncheck certain boxes which I did. She told me the webcam is used by several programs on the computer and in the end she had me blocking certain startup programs. In the bottom right of my monitor their is an icon for "Blocked startup programs." When she had gotten to the end of guiding me here and there, checking or unchecking boxes...the webcam had started working. It is important to mention though, it had worked sporadically since I bought the laptop. So, was this just a coincidence? The next time I went to use the webcam, I was right back at square one. The webcam was not working again and giving me the same old messages.I was really ********** because I had done everything she had told me, and in addition, I now had blocked startup programs and still had the same problem with the webcam that I had from the very beginning. Also, it seems kind of ridiculous to me that I had to block certain startup programs to begin with. A new computer and you have to block certatin programs to use the webcam. (Just also remembered, I have a burner on this laptop and when I have tried to burn downloaded songs to disc, it shows that songs are being burned, but upon playback the disc has nothing on it. My sister tried using the disc after to burn music...thinking maybe the burner had not done anything to the disc... and the disc would not record a thing. :-( It just became a piece of garbage. I did this with three discs. She took two of my remaining discs and burned downloaded music and did playback on her own pc with no problem whatsoever. So, based on this, the discs were not the problem.)
Back to the webcam problem: For your information, I have closed yahoo messenger and windows live messenger to see if that makes any difference. The webcam still does not work. Now and then...by no means always...I shut down the computer and sometimes...not very often, however, when I try to start the webcam the stupid thing works. Right now, it is not working again and I am at a total loss for answers and extremely frustrated. My gf is a nurse stationed in Afghanistan. I am able to see her camera, but she is unable to see me. When I try starting my webcam she just sees the same words that I see... that I
have cancelled my invitation to view webcam. It is very upsetting to her that I haven't been able to get this problem fixed. Could you please contact me at your first opportune moment and if at all possible help me to fix this problem once and for all. I would be deeply appreciative and I assure you she will be also.
I am running Windows Vista Home Premium. The laptop is a Toshiba Satellite T2080. When I scanned the laptop with Driver Detective...I think that is the name of the program...it said the laptop is A200. I don't know if that helps you or not. In any event, whatever information you may need that I have not provided... in your correspondence simply direct me to look for... or do whatever is necessary to help you resolve the problem(s). In the meantime, I hope I have not confused you with my explanation of the problems by being so long winded. I am more than a little anxious to hear from you very soon! Thank you.
Sincerely,
Gordon Mackey have the same problem but my laptop is a305 s6872 (model number psag8u) and all of the sudden, the other day, the webcam refused to work for me. is it funny how the tech support ppl always want you to rebbo the comp. well i refuse to do...so please help anyone.
i tried uninstalling the webcam and installing it back and forth a couple of time but with no success. help anyone thanks :(
    Scholar:
  • 69 Answers
With most laptops, being proprietary, there is a lot of installed software that you don't need. One good thing to do is go to "Add / Remove Programs" in the control panel, and remove any Toshiba software you don't need.
While in the control panel, find the "User Controls" and disable it. That will stop the system from blocking startup programs. Vista Home Premium is really bad about crossing wires with drivers and other functions when it comes to instant messaging and web cams.
After you've removed all the unnessary junk software and shut off the User Controls - uninstall and reinstall the drivers for the web cam, and reboot your computer. Use your web cam through your instant messenger service only, and most of the time it should work. Also, if you're using a password to log onto your system, get rid of it (the password) by going to Users in Control Panel and select to change you password. Leave the "New Password" fields blank, and click "OK" or "APPLY" so there are no limits to the use of the system.
This is the method I used to fix one of my customer's Toshiba laptops and it works to this day (7 months now).
If all else fails, disable the onboard camera and buy and after market camera to be used through the USB port and that should also solve the problem as it will be a 3rd party install and not a Toshiba proprietary.
Posted on May 25, 2009
I have a Toshiba Satellite P205-S6237 with a built-in Chicony USB 2.0 camera, I cant get it to work, need help
Many Toshiba laptops, including Satellite, Portege and Qosmio models, feature built-in Chicony-brand webcams.
The Chicony webcam can be problematic, especially when running a 32-bit version of Windows Vista.
Microsoft has released an update that will correct problems with starting the webcam after terminating "Sleep" mode.
Users may also have to install the appropriate driver or webcam software to correct webcam problems.
Dark or Black Webcam Image Problems
Toshiba laptop owners may have problems with the webcam displaying as dark or completely black a few seconds after the initial image appears or immediately after engaging the webcam.
Users should ensure that the webcam indicator light is engaged.
If not, users should run the "Camera Assistant Software" to turn on the webcam.
Low light can cause the webcam to power off and to display a dark image.
Users can tweak the light and contrast by manually increasing the lighting in the room or by turning on "Night Mode."
If these steps do not correct the dark image problem, users may have to reset the webcam itself, reinstall the "Camera Assistant" software.
Webcam Problems After Terminating Sleep Mode
Toshiba laptop owners with Windows Vista (any 32-bit edition) installed and the Chicony webcam may have problems starting the webcam after restoring the laptop from "Sleep" mode.
"Sleep" mode powers down a number of hardware components in the laptop.
The webcam is capable of entering a non-operating system-induced sleep mode when it is not used for an extended period of time.
After the user engages Windows "Sleep" mode and wakes the laptop, the webcam may give error messages such as "Locked by another application."
This webcam problem can be corrected by installing a Windows Hotfix, which is also included in Vista Service Pack 1 (SP1).
Webcam Problems After Upgrading Windows Vista
Toshiba Satellite laptop owners may opt to use the Microsoft Anytime Upgrade to upgrade to Vista Ultimate.
After doing so, the Chicony webcam may stop working and report a "Please turn on the camera" error message.
Users can correct this problem by reinstalling the Chicony driver.
Webcam Problems on Linux
Linux users who own Toshiba laptops with the Chicony webcam should install the Linux UVC Driver to make the webcam functional. The webcam may not work without this driver.
Grainy or Blurry Webcam Image
The Chicony webcam can produce grainy or blurry images if the user does not remove the protective film that covers the external webcam interface.
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: webcam name webcam driver you might have to try a few times to get it right
software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
It might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you
want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Hope this helps
Nov 15, 2012 | Toshiba Computers & Internet
Webcam not working
1. Click the Windows Start button.
2. Click Control Panel and then Device Manager.
3. Double-click Imaging Devices then right-click on Chicony USB 2.0 Camera and select Update Driver Software.
4. Select Browse my computer for the driver software.
5. Select Let me pick from a list of device drivers on my computer.
6. Select Chicony USB 2.0 Camera from the list, and click Next.
The webcam should now work properly.
or any name of your camera in the list :) i hope it works for u.
Jul 03, 2010 | Computers & Internet
Error: Webcam driver open fail. Problem with Satellite A305D
sounds like driver related problem, download this tool: Driver Update Software for XP Vista 7 8 update your drivers, and won't be any problem.
Jim
Jun 15, 2010 | Toshiba Satellite A305-S6845 Notebook
Can't Acess My Chicony U.S.B Webcam, no icon, ALWAYS WORKED
try to start the interface of webcam using :
1. start menu > programs > chicony webcam
2. open C: drive > program files > chicony webcam and double-click "chicony.exe" file
3. in the properties, check "show in task bar"
Dec 31, 2009 | Computers & Internet
Chicony USB 2.0 camera will not work
Please uninstall the camera from Control Panel->Ad Remove Programs and reboot. Then insert the CD that came with the camera and install its drivers. Reboot. Now attach the webcam and allow Windows to detect the webcam and load its drivers till you get a msg in the right bottom corner of the screen saying "The new HW is installed and is ready for use". Now start MSn and configure it for this webcam as default webcam and save settings. Now you can start your Video Calls.
Dec 08, 2009 | Computers & Internet
My toshiba web cam is not working,
Windows Vista has compatibility issues with many webcams because the ACPI is different; need to know the make/model of your webcam.
I am assuming you have a Chicony USB 2.0 Webcam made by Toshiba...
CHICONY USB WEBCAM DRIVER
Aditional Toshiba Support for Webcam Hardware
Nov 28, 2008 | Computers & Internet
Well it's not a complete solution but this does work. It's just a bit of a pain. Go to Control Panel > Device Manager. Now you have one of two options either update the software this works from time to time. Alternatively, disable the camera. Restart and enable it again and it should work.
Hope it helps,
Phoenix
Nov 11, 2008 | Toshiba Satellite A135-S2386 Notebook
Webcam
the resolution to this issue is that you need to reinstall the device driver software of your webcam. normally the name of the webcam on device manager is chicony usb 2.0 camera. visit support.toshiba.com, go to downloads and find the model name of your toshiba laptop. download Camera Utility Software.
i hope this helps.
Sep 12, 2008 | Toshiba Satellite A100-S8111TD Notebook
Chicony USB 2.0 Camera: NEED HELP!!!!!
Follow these steps to re-install the driver for the webcam. You will need to be logged in as an Administrator or have an Administrator password ready.1. Click the Windows Start button.
2. Click Control Panel, System and Maintenance and then Device Manager.
3. Right-click on Chicony USB 2.0 Camera and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver
6. Select USB Video Device from the list, and click Next.
7. If the message “Windows encountered a problem installing the driver software for your device” appears, click Close.
8. Restart Windows.
May 24, 2008 | Computers & Internet
LAP TOP CAMERA
Re-install the driver for the webcam.
8. Restart Windows.
You can check this link
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1924621xml&sliceId=&dialogID=36590569&stateId=1%200%2036586710
You can update the drivers here
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1596141&rpn=PSAD6U&ct=DL&BV_SessionID=@@@@1918347540.1210491665@@@@&BV_EngineID=cccjadeedgmlddhcgfkceghdgngdgnj.0
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A305-S6863 Laptop Logo
703 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
