Question about TruTech PVS12701 Portable DVD Player
Remote wont work,even after new batteries
My Tru Tech remote has stopped working. I changed the batteries with new ones and the only other thing that could of effected it was that it got wet on the bottom with a little water. Any chance of fixing it or is there a universal one I can buy at store? Thanks for your help
  • TruTech Master
  • 5,568 Answers
Although I have had bad remotes, it isn't that common and if you have any consumer repair service near you, they will probably have a primitive IR tester that will tell you whether the remote is outputing anything. If it has output, it's probably OK. The IR receivers (inside your set) seem to fail much more often so replacing your remote may not help.
If you still want to try a new remote, don't buy at random; the likelihood that it will work is pretty much 'remote.' So-called 'universal' remotes should be called 'multibrand' since even the cheapest of them will communicate with hundreds of different devices - but none of them will cover all.
I suggest (if you want to try one) that you jot down the make and model of several, then go to their website(s) (if they have none - stay away from those), check for their latest code listings to see if your TruTech is covered. That is not a real common brand so may not be offered in many of them.
Posted on May 25, 2009
The remote is not working at all, example the lights not turning on and i even try'd changing the batteries still not working. What should i do.
mtousar
I would first check that the batteries (+) is all pointing down in the remote. If they are all pointing down, then you probably need a new remote. Call 1-800-333-3474, speak with Tech support to get another remote. I hope this helps.
Ray Calo
DISH Network
Feb 03, 2011 | DISH Network IR Remote Control
I got Two TV's My TV Connected to remote 1 in IR mode. After trying to record some thing using dvr the remote dies on satellite cannot change channel... Tech team tries every thing send new remote and...
topscrew2002
From what you have written, when you try to record on your DVR the remote stops working, is that correct? How long has this been happening? Have you received a new remote? If yes and it is still happening, you are probably getting IR interference from some source in that room. It could be from a florescent lamp, another player, or even the TV. Is the receiver in a open space or in an enclosed area? The IR sensor has to have a direct line of sight to work properly. You may also check on the receiver if anything is obstructing the sensors, maybe dust. I hope this helps.
Ray Calo
DISH Network
Dec 02, 2009 | DISH Network IR Remote Control
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Remote won't work
reset the default setting go to menu button and manualy do this.....
Jun 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Remote Control wont Work
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
TRU TECH TV CODES
try code 10030 (comcast remote), or codes for daewoo.
Mar 28, 2008 | TruTech PLV16190 Television
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
did you spray the cleaning solution right onto the control panel?? Well if you did you may have shorted out your remote sensor eye. If irt dosent dry out in a few days then your gonna need a new one. Go to http://partstore.com and they will assist you finding what you need. Good luck
Apr 23, 2006 | RCA 32V550T 32" TV
TruTech PVS12701 Portable DVD Player Logo
433 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
