Question about Frigidaire FRT18S6AQ Top Freezer Refrigerator
Frigidaire frs20zgf freezer doesn' keep making ice
I tightened and cleaned everything but not it pour wate into tray and drips completely into freezer. can you help?
SOURCE: Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Posted on Jan 11, 2008
  • 1462 Answers
SOURCE: Water collects in the bottom
drain is blocked probably with ice. take rear panel off, melt ice off with hairdryer and follow up with hot water till water flows away freely
Posted on Jul 18, 2008
SOURCE: Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Posted on Jul 22, 2008
  • 298 Answers
SOURCE: Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Posted on Jan 17, 2009
hiltonjug
  • 612 Answers
SOURCE: Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Posted on Nov 12, 2009
Testimonial: "I turned off the freezer side and it defrost for a few hours. Then I turned it back on and its working fine for 2 days now. "
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
Oct 29, 2013 | Refrigerators
Water keeps dripping out of ice maker line over filling ice tray wont stop dripping
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 29, 2011 | Hotpoint (HSM25IFTSA) Side by Side...
On a frigidaire model frs26lh5ds1 side by side prost proof, the ice maker doesn't make ice. the water drips down into the tray and freezes there. any suggestions?
Leo Ponder
imufo2
Jul 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
My Frigidaire side by side is not making ice. (Model GLRS267ZAW1)It goes through the cycle but no water is getting into the icemaker. I can pour water in to the icemaker and it makes the ice and dumps it....
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Oct 03, 2009 | Freezers
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Leaking side by side
You have to unclogh the drain hole inside the freezer at the bottom of the back wall by pouring hot water into it until ice melts and keep pouring to make sure water goes through .Repeat this every 3 o 4 months to keep it clear.
Jul 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Plugged defrost drain line in KitchenAid Refrigerator KTRS22KHBT00
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
algae, bread ties andf other thing mysteriously get in there and clogg it
Jan 10, 2009 | Refrigerators
Freezer ice
Jan 08, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Frigidaire FRT18S6AQ Top Freezer Refrigerator Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
