USB/SD Cards no longer Responding/Recognized
So, a couple months ago our mouse just suddenly crapped out, along with anything else that required a usb hookup (keyboard excluded).
We've since come to realize that the front ports and the SD/etc. Card Reader slot also no longer works.
While this is not a necessity it has hindered many of our options with the technology.
So far I have checked out and done all I can in device manager (driver install, uninstall, reinstall, update, rollback, rub it's belly and pat it's head), the device manager at first stated that the devices were not being recognized on the harddrive.
I was recommended to try reformatting if nothing else worked, and even a reformat didn't do it.
Do you think this is a hardware problem; should I just try and find a new usb/card reader drive, and if so, can you point me anywhere? I'm having the worst luck.
  • marimother May 26, 2009
    Oh thank you both so much!
    I am going to try this first thing in the morning, and announce how it went.
  • 256 Answers
From my experience, the problem is reistance and corrosion. Most connections on the motherboard are pushon. Open your computer, find the wires from the front USB devices and 1 at a time gently pull them off and push them one at a time. The rubbing of the two parts should give good contact again and get your devices working. The same happens with hard drive and CD/DVD data cables. It won't hurt to give it a try, just be carefull not to mix up connections or break anything.
Posted on May 25, 2009
    Scholar:
  • 93 Answers
If you open up the pc case you will see the bundle of wires that lead from the front reader to the motherboard. Make sure they are tightly plugged in. If that does not work there should be another USB connection on the motherboard near it, unplug it from the original connection on the motherboard and plug it into the second board see if that helps.
Joe
SD card not recognized
What happens when you tried to plug-in SD card to the computer?
Have you made any recent changes to the computer prior to the issue?
To make the SDHC be recognized by the computer, we need to ensure that the card reader works in Windows 7 first. Please check if the card reader is recognized properly by the computer and you have installed the driver for it.
Meanwhile, you can plug some other storage cards to the card reader and see how it works.
I would suggest you to refer the link below
A Secure Digital (SD) card may not be recognized on a Windows 7 based computer.
http://support.microsoft.com/kb/981642
Uninstall all the Generic USB drivers and reinstall.
1. Open Device Manager.
2. In "Disk Drives" dropdown, uninstall the "Generic SD/MMC USB device" drive.
3. Restart computer.
4. Insert SDHC card.
Hope this helps.
Nov 25, 2012 | SanDisk Electronics - Others
8GB SD card says: MEMORY CARD REQUIRES FORMATTING After selecting continue SD card says: FORMATTING WILL DELETE EVERYTHING ON MEMORY CARD after selecting continue it says: FORMATTING... but then returns...
i guess you are using it thru a USB, try a differnt USB port if you have more than one USB port on your PC....else
try it on a different PC
or
a longer solution is to get a low level format software like "killdisk".....this is also a DOS based application....install it and use the in Win or thru a boot diks DOS application
revert back
Jan 06, 2011 | PNY 2GB microSD Memory Card
Computer will no longer recognize microSD
Go to Device manager and totally remove/un-install ALL/ anything USB...
Then reboot the PC, DO NOT plug anything USB in yet.
PC will start then install usb structure.. then reboot.
NOW try ya USB things ... ya prob good to go.
Jan 18, 2010 | PNY 2GB microSD Memory Card
My MX1100 cordless mouse no longer recognized
It sounds like the Drivers for the Mouse aren't be installed. Since it is a wireless mouse and receiver it will need separate drivers to function properly. If it came with a CD I would try re-installing any software that came on the disc. If not (I'm assuming its a Logitech Mouse here) I would visit the Logitech website (www.logitech.com) and see if you can locate Drivers there.
Jul 08, 2009 | Computers & Internet
USB DEvice not recognized
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Jan 01, 2009 | Video Cameras
Bamboo Fun usb device not recognized
Change the USB cable... this is the problem...
Sep 22, 2008 | Wacom Bamboo Fun USB Tablet with Cordless...
IPod is not recognized
i have the seem probleme since i have installed a new firmware somone know where to find the original firmware ?
Dec 28, 2007 | Apple iPod MA446LL/A MP3 Player
Wireless mouse problems - responding incorrectly
Try to reinstall Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 30, 2007 | Belkin F8E874 Mini Wireless Optical Mouse
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
