Question about Creative Labs ZEN V Plus MP3 Player
Wont turn on
My Zen Vplus (4gb) turns on but the music wont play and the screen graduattly get dimmer until it shuts of. If i hold the power button down it will stay on but the music wont play and its says its locked up by the battery. HELP!
    President:
  • 688 Answers
You need a new battery for you zen
look on ebay.com
or do a search for creative labs zen vplus battery
on the inetrnet
Posted on May 26, 2009
Frozen on rebot screen
First reset it to turn it off then do this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Apr 20, 2009 | Creative Labs ZEN V Plus MP3 Player
My zen wont play an y music
try sliding down the power button while holding down play and resetting the zen while the player is off, this should bring you to the zen format screen thing, select "clean up" if this doesn't work try selecting the other options from the zen format screen thing.
Jan 18, 2009 | Creative Labs Zen Digital Media Player
Zen Vplus 4G problem
try leaving it connected to the usb and pressing the reset at the same time
Sep 02, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen VPlus 4G
press the reset button while its connected to the usb-worked for me-not sure why but it did-
Problems
try putting it in recovery mode, detach it from anything like a charger or pc make sure that it is off, press and hold the play button while powering on, when you see the logo release the play button, for this problem you must se;ect the reload os firmware and then follow instructions
Mar 28, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen vplus 4gb Stuck on start up screen that says "ZEN vplus"; it will not shut down once on, unless using the reset button
see recovery mode info here:
http://www.anythingbutipod.com/forum/showthread.php?t=6714
(thank you)
holding play button while powering up, then running Clean Up & rebooting did the trick.
Mar 14, 2008 | Creative Labs ZEN V Plus MP3 Player
The button of my player Zen V Plus 4GB, the on and off switch loose
usually its 0000 or depending how many numbers. all zeros. just do a clean up. insert pin in reset hole while holding down power button, then let go, select clean up, let it sit and do its business, then when done, reboot
Feb 12, 2008 | Creative Labs ZEN V Plus MP3 Player
MY ZEN WAS WORKING FINE AND NOW THE SCREEN IS BLANK
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Jan 23, 2008 | Creative Labs Zen Nano Plus MP3 Player
Mp3 player
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 30, 2007 | Creative Labs ZEN V Plus MP3 Player
STUCK in RECOVERY MODE
Clean Up
Format (All)
Reload OS/ Firmware
Dec 17, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
164 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
