Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Green picture hi the picture is perfect for tv but when i play a dvd it is really green, it wont allow me to select 'hue' any ideas?
  • alesiasntg Jan 05, 2009
    I have the same problem. tv is fine except when i play a dvd. sometimes the green goes away in the middle of the movie, and back to regular colors, other times it doesn't.
Try to connect wires stronger or replug wires
Posted on Jan 02, 2009
Sounds like a poor connection with a scart lead
Posted on Oct 26, 2007
SOURCE:
My sony tv has a all green picture do i need to replace the lamps
greenish hue ? if so no the lamps typically control the brightness and allow the image to be transferred to the sets screen through the optic block and thats what i believe to be the culprit to your hue it it is a hue if not other issues could be amiss
Dec 21, 2010 | Sony KP-51WS500 51" Rear Projection...
Ny sony sxrd kds r60xbr1 has a green hue . was
Hi,yes if you get a blue hue is has to do with the optical block .You can find it here : http://www.discount-merchant.com/SONY-1-867-732-14-Light-Engine-w-Color-Wheel-p/1158118.htm?Click=48173 maybe youcan find instructions on ebay.
Nov 28, 2009 | Televison & Video
Green hue
Unplug the TV from the wall and plug it back after 45-60s should fix the problem. However, it will come back from time to time so the same procedure will reset the video board. You'd want to upgrade the firmware on the ATSC tuner as well because old firmware was built before the final standard and when the TV goes digital in June 2009, it wreak havoc on all older HD TV. Go to hitachi website and download new FW for your TV. Copy the FW to an SD card and follow procedure from Hitachi to upgrade. It works wonder for my TV after the upgrade.
Sep 22, 2009 | Hitachi 53UWX10B 53" Rear Projection...
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
Dvd movies have green shade on tv
Check to make sure that *all* the RBG cables are properly inserted into the dvd player. We had the exact same problem for the past year only to discover that the R cable (for red) was not pushed in...hence, all dvd movies had a green hue to them.
Mar 08, 2008 | Televison & Video
Vizio 37" LCD color problem!
is the TV still under warranty. if it is I would call Vizio and request a main board be switch and if it is not under warranty I would call a TV Repair shop and have them put in a Main Board.
Mar 04, 2008 | Televison & Video
GREEN AND RED HUE IN PICTURE WITH CABLE OR DVD
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Televison & Video
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
199 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
