Question about Nokia 6680 Handheld
Nokia 6680 my nokia 6680 won't power on and it's not becouse of charger or battery. my contract finished with three network long time ago, could it be the reason why it is not power on?
  • Anonymous Jan 05, 2008
    removed battery and replaced tested charger
  • 490 Answers
No sir,no issue with the n/w....it is problem with ur handset battery....change it ir charge it fully then try....
Posted on Oct 22, 2007
I have nokia 6680 I I forgot screen lock code when I turn my phone on it asking for lock code so now how I can open it ?
How can you forget a code you set and have been using multiple times a day? The default code is 12345. If you 'found' the phone, perhaps it is still set to the default.
NOKIA 6680 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/nokia/nokia-6680/hardreset/first-method/
Hard Reset NOKIA 6680. First method: Power on your handset. Hard Reset NOKIA 6680. Then please press and hold * key + 3 key + Call button + Power button, until you see Nokia logo. HardReset NOKIA 6680; After that enter your lock code. * The default lock code is 12345; Now your phone will reset and restart.
www.hardreset.info/devices/nokia/nokia-6680/hardreset/third-method/ Hard Reset NOKIA 6680. Third method: Switch on your phone. Hard Reset NOKIA 6680. Next press Menu button and goto Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore -> Yes Factory Reset NOKIA 6680; Then your device will reset and reboots. That's all. See the Previous method!
www.hardreset.info/devices/nokia/nokia-6680/hardreset/second-method/ Hard Reset NOKIA 6680. Second method: Turn on your cell phone. Hard Reset NOKIA 6680. You should now type this code: *#7370#; Then press your lock code. * The default lock code is 12345; After that your phone will reset and restarts. Success! See the Previous method! See the Next method! How to Hard Rest NOKIA ...
Nokia 6680 hard reset
www.hard-reset.com > Nokia hard reset Apr 3, 2010 - Nokia 6680 hard reset: Press these buttons * + 3 + call + Power on your phone. Before the device is reset, you need to provide the lock code. The default lock code is.
Nokia 6680 Hard reset - How To Factory Reset
https://www.hardreset99.com/nokia-hard-reset/nokia-6680-hard-reset-factory-reset/ Feb 18, 2017 - Nokia 6680 Hard reset and Factory reset. Forgot your android mobile Password or PIN or Pattern, Here you can get recovery solutions for free.
NOKIA 6680 Hard Reset - IMEI.info
www.imei.info/hard-reset-1350-nokia-6680/ Are your looking for a way to make your NOKIA 6680 work faster? Do you wish to clear all of the data on your NOKIA 6680 before selling it to someone else? Well what you need is the factory reset. What is it? Factory reset (aka hard reset) is an operation which deletes all data (including settings, applications, calendars, ...
videos
nokia 6680 hard reset Google Search
Mar 24, 2018 | Nokia Cell Phones
Nokia 6680 charging problem
this is a common problem with mobile phones if the battery voltage drops to low the phone canot control the initial cherge remove the battery and charge out of the phone if you can or by a new battery which will have a small charge in and should allow you to cherge the phone normaly
Dec 14, 2008 | Nokia 6680 Handheld
NOKIA 6680 DOES NOT CHARGE
well the problem is in your phone hardware,probably the "charging I.C". try to bring it on a service center..
Oct 27, 2008 | Nokia 6680 Handheld
NOKIA 1208
might be Loose battery connection.
Bad battery.
Bad charger.
Bad phone.
Bad connection somewhere.
So remove your battery, clean the contacts and reinstall. If the battery is bad, replace it. If the charger is bad, replace it.
If these things don't solve your problem you are left with replacing the phone.
Oct 18, 2008 | Nokia 6680 Cellular Phone
Need unlock code for NOKIA 6680
my phone can not access network.mobile centers told me its a country lock. i bought the mobile from singapore. its nokia 6680
Sep 22, 2008 | Nokia 6680 Cellular Phone
Please help me!
just go to technician and reinstall the software for ur cell this is called flashing...
this solves ur password problem....
about ur battery problem , just have check wit the battery in another set and check the battery back up...
or may be u r not using the original charger to charge due to this battery may have gone dead...
if not just visit to near by expert techinician...
Jan 30, 2008 | Nokia 6680 Cellular Phone
Reprogram my nokia 6680
Full phone formatting on a 6680!
If you encounter situation like below on your 6680,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6680! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6680 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6680 phone.
Remember, do not let go all of the keys and hold keys until you see a Nokia turns to white and blink' and nokia logo!
5. After a few minutes when the Full phone formatting completed, your 6680 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Thank you for rating this Tip.
Dec 26, 2007 | Nokia 6680 Handheld
Ot charge
Either your charger is not working, or your battery is need a replacement.Buy original.
Dec 08, 2007 | Nokia 6680 Handheld
Nokia 6680 Handheld Logo
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
