Question about Dell Inspiron 1501 Notebook
Computer won't boot
My Dell quit working and when I turn it on it continually wants to run startup repair. I let it run and then it shuts itself down - windows won't boot.
  • bonesrandis5 May 25, 2009
    I was not able to the HDD diagnostics. I found the HDD password.
  • 323 Answers
Turn it on and begin to tap F8 continuously until you enter a screen that gives you different boot options. It sounds as though your Master Boot File is corrupt.
If you come to a screen that allows you to choose "Last known good configuration" choose that one.
If it doesn't work, allow it to run start up repair.
One of the options you should see is to repair the Boot file, or MBR, or master boot record. It takes mere seconds and should reboot you.
If you didn't make Recovery Disks when you bought the machine, make them as soon as you get it back in order. They do the job much more easily!
Posted on May 25, 2009
  • Dell Master
  • 1,183 Answers
I assume, you have windows Vista, on your computer. If the startup and repair is not repairing the system. The operating system has crashed.
If you have the windows VISTA dvd , there is a possiblity to run startup and repair from the dvd to fix the problem.
But before you do the same, just run the diagnostics on your harddrive.
1. restart your computer
2. Tap on the F12 a couple of times when u see the DELL logo
3. Select HDD diagnostics
Post back the results
Thanks
Proton
Error code 2000 0146
The error code refers to a faulty or failed hard drive. You may try the following steps and check whether you can resolve the issue.
First you may try boot in safe mode and check what happens.
Step 1: To boot to Safe mode you can follow the below given steps:
1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button, click the arrow next to the Lock button, and then click Restart.
2. Do one of the following:
a. If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
b. If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in Safe mode, and then press F8.
For more information, you may refer the following link on Safe mode:
http://windows.microsoft.com/en-US/windows-vista/Start-your-computer-in-safe-mode
If you are able to boot in Safe mode, then try a Clean boot.
Step 2: Try to perform a clean boot and verify if any of the services or startup items is causing this issue. To perform a clean boot we will have to run System Configuration Utility.
To perform clean boot, follow the steps:
1. Click Start, type msconfig in the Start Search box, and then press ENTER. If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
2. On the General tab, click Selective Startup.
3. Under Selective Startup, click to clear the Load Startup Items check box.
4. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
5. Click Apply and OK.
6. When you are prompted, click Restart.
7. After the computer starts verify whether you are able to do backup.
If your issue is resolved after performing Clean Boot, then follow the steps mentioned in the following KB article to narrow down the exact source:
http://support.microsoft.com/kb/929135
Also, see the section on how to return your computer to a Normal startup mode by following the steps under "Reset the computer to start as usual".
If the above steps don't resolve the issue, then try a Check disk to repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors
Step 3: Run Check disk to repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors.
1. Click Start, and then type cmd in the Start Search box.
2. Right-click cmd in the Programs list, and then click Run as administrator. If you are prompted for an administrator password or confirmation, type your password or click Continue.
3. At a command prompt, type the following command, and then press ENTER
chkdsk /f /r X:( drive letter)
4. Press Y when you are prompted to check the disk the next time that the system restarts.
5. Close all applications, and then restart the computer.
If check disk also fails then you may need to get in touch with Dell for more assistance.
For more information, you may refer the following Dell support links:
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6&journalid=7B57AFAEEF1E9C6FE040AE0AB6E1044C&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=7B57AFAEEF1E9C6FE040AE0AB6E1044C&treeid=345518
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=7B57AFAEEF1E9C6FE040AE0AB6E1044C&treeid=324398
http://en.community.dell.com/forums/
Hope this information is useful.
Oct 02, 2013 | Dell Vostro Computers & Internet
Fan on Dell M5030 Starts on startup and then shuts down but computer continues to boot
Lots of fans are variable speed. Meaning they spin faster when the computer is hot and slow down when not. It's most likely spinning down. If the fan was bad the computer will either shutdown or generate an error during BIOS and halt the boot process.
Jan 11, 2013 | Dell Inspiron M5030 Laptop
I have a dell vostro 1400running on Windows 7 yesterday i tried to install and old software for an mp3 player and it said when running it there are some compatibilities problems the laptop shutted down...
Restart the computer couple of times, you will get an option to run startup repair. Use your keyboard up / down arrows and highlight the startup repair option and hit enter. This will run startup repair and should solve the issue.
Mar 01, 2011 | Dell Computers & Internet
When ever my computer shutsdown it goes to startup repair. sometimes it works itself out. but every morning i wake up to it with the startup repair screen on
Sartup repair is some thing that tries to fix the OS issues...
Normally its of no use.. Its better if you can reinstall the OS after getting windows and taking backup of all your important files..
It should be vista or win 7 that you have on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you are not able to do this then try to reinstall the OS with the help of a OS CD..
Sep 28, 2010 | Dell Studio 17 Laptop
Computer windows will not come up
Try This:
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
When i on the system, the fan is not rolling, sometime when on and boot upto the the window evironment, its shut itself down. what could be the possible problem with them
Please Check CPU making any noise or not.
remove the CPU side door and check Fan is rotating on Processor if not it may not rotate due to heavy dust inside. ( clean it and refix it)
Check SMPS Fan is rotating or not..
If fans or not rotating Heat Builds up then computer shuts down itself.
If both fans are working...Just Open BIOS window by press DEL button continuosly while startup and wait for 2 to 3 minutes If the computer shuts down Itself in BIOS Window also then we can confirm issue with Hardware.
If Computer not shutting down in BIOS Window then issue with Operating System Boot files corrupted.
While Turn ON the system press F8 to enter in Safe Mode.
Open command prompt by clicking on
Start >. RUN >> type cmd >> then press enter.
now type chkdsk /f
now press Y
then reboot PC it fixes the Boot files error then your PC works perfectly.
If you still exp same issue let meknow..
Feb 18, 2009 | HP Pavilion dv6000z Notebook
Apple G5 Locked up
Sounds like you have a permissions issue, first boot in single-user mode and repair permissions.
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Jan 22, 2009 | Apple Power Mac G5 Desktop
Boot/Startup repair problem
Microsoft updates do it again!!!
while the PC is booting up his F8 repeatedly, if it lets you into the sub menu boot into safe mode and perform a system restore, take the computer back to before you did the updates, if this works and your computer is restored, turn the automatic updates off
kind regards and please don't forget to vote
Dec 12, 2008 | Acer Aspire 6920 Notebook PC
Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
  • There appears to be a shortage in one of your lines to you computer. But, before you replace anything, try these methods.
  • Shut down the computer.
  • Remove any CDs, DVDs or external storage devices (like USB keys or external hard drives) from the computer, if any are present, then press the power button to turn the computer on.
  • Press and hold the <F8> key as your computer starts. You need to press <F8> before the Windows logo appears.
  • If the Windows logo appears, and the system still fails to boot to Windows, shut down the computer and try again.
  • From the Advanced Boot Options menu, use the arrow keys to highlight Repair Your Computer, then press <ENTER>.
  • Click to select your language, and then click NEXT.
  • Log in as a user with administrative rights, and click OK.
  • From the Choose a recovery tool menu, click Startup Repair .
  • Once completed, click FINISH.
  • Click RESTART.
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
Oct 03, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron laptop will turn on but wont take me to log in screen
This indicates a hard drive failure. Try reinstalling the operating system, if you have any problems during or after the reload, then the hard drive is bad and needs replaced.
Jul 03, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
124 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
