2000 S40, hard starting, ran the battery down cranking. Smell gas. When it does start, the temp gauge fluctuates from the bottom peg to the top peg. Idles at 4000 r.p.m. Check engine light on. As the car is to be stored I put some Stabil in the gas according to mfg. specs.I also had the coooling system flushed and filled, and installed a new thermostat, no help. Could it be a temp. sensor?
  • 3,741 Answers
Yes its the temprature sensor problem.
For the complaint you're describing, typically the ECT (engine coolant temperature) sensor is out of range. By that I mean that the voltage being relayed back to the engine computer is incorrect for what the ECM expects to see for the length of time the car was run, the load, etc. The "check engine" light should be on if that's the case. The thermostat should usually be replaced at the same time since it's right next to the sensor. The thermostats usually fail by beginning to open too early which does not allow the car to warm up properly. The ECM is looking for a certain temperature within a certain amount of time after initial startup. If it doesn't see the temp (from the ECT sensor), then it will turn on the "check engine" light. If the sensor is out of range, the engine control module "assumes" a worst case scenario (overheating) and turns the fan on. It will run 6 minutes after the key is turned off and will turn on immediately after the car is started if that's the case.
The sensor is right behind the power steering pump on the lower portion of the thermostat housing. The connector for the sensor should be attached to a plastic clip attached to the top of the pump bracket. When replacing the sensor, the top part of the thermostat housing has to be removed for access, which is why it's easy to put a new thermostat in at the same time. cheap insurance also. Use a Volvo thermostat. We've had problems with aftermarket parts opening too soon and causing the "check engine" light lately.
Your ECM should also have been updated if you had the sensor done at a dealer. There is a tech note from volvo telling us to update the software when the new sensor is installed. There should be no charge for the software as it's loaded into the dealer computer, but they'll usually charge you labor for the hookup and download. Hope this helps!
please do rate the solution.thank you for using fixya.keep updated.thanks
Posted on May 25, 2009
2001 Volvo s40 seems to stall and not start for ten to 15 min. Also has high temperature reading that is false as car is not really hot.
You need to look at the temp sending unit it's probably faulty anthor issue with volvo is dirty throttle body's this raises havoc on the car they idle up down all over the map also you should change the thermostat too as a precautionary measure make sure it's the right temp for your year of your car thanx Chris
Mar 04, 2014 | 2000 Volvo S40
My 95 chevy suburban 5.7 temp. gauge fluctuates from operating temp 195 to 170 back to 195 as I drive
there are two things that can be wrong here.
1-wiring or the sensor itself may be bad.
2-you have a bad head gasket(not blown all the way)but starting to go therefore the fluctuation on the gauge itself.
does it go down when you give it gas? does it uses coolant with out leaking? let me know
Oct 14, 2013 | 1995 Chevrolet Suburban
Car ran out of gas and has been hard to crank every since. I don't hear the fuel pump prime but I do hear the relay click. There is no gas expelled or pressure coming from schrader valve and also batt
the fuel pump is burnt out. the pump uses the fuel to cool itself. running low fuel the pump heats up and burns the plastic gears inside. thats why the fuse blew. need to take out gas tank to change pump.
Mar 11, 2013 | Cars & Trucks
2000 s40 runs good but very hard to start
I ran into this a month ago. Check your battery. Volvo's and other euro cars are very picky about cranking voltage. have a friend put a volt meter across the battery while you are cranking. If it drops much below 11 volts, its probally not going to start. Have a shop load test the battery. Hopefully, this is the cheap fix to your problem. (my other customer had spent over $300 at the dealer)
May 02, 2010 | 2000 Volvo S40
My gas hand has flipped around to bottom of fuel gauge and is hitting peg on bottom. How can i get it back around to correct position. The car died as the gauge was coming up to full and needle continued...
Fuel pump!perhaps not working!sit in car turn ignition on do not atempt start or crank engine you should hear a grunt sound from back seat area like a GRRRRR if not fuel pump not working!
Dec 28, 2009 | 2006 Nissan Maxima
1999 buick when fuel gauge drops below 3/4 it is is not accurate
i dont know the specifics of a Regal, but usually, when a needle fluctuates too much, is because the float gauge in the gas tank is worn out, or its mount became loose. You cant see that effect on a full tank because the instrument needle and the float are pegged against the stop.
Nov 23, 2009 | 1999 Buick Regal
My 2000 eclipse wont start up all the way
I have the same problem on my 2002 Eclipse RS 2.4l 4 cylinder. Replaced the battery, starter, fuel pump(not at one time) . It started up when I had the starter put on as well the fuel pump. But everytime I started the car up it ran good till I turned it off the problem was still there. The car sounds like it wants to start but it sputters you can smell the gas so I know its getting fuel. it starts up fine with a cold start like in the morning.
Try getting a diagnostic thats what Im going to do next week.
good luck!!!
Jan 24, 2009 | 2000 Mitsubishi Eclipse
Instrument panel dials all pegged to zero or max
ok let me help you get started
this isnt going to be easy we need to do a bunch of testing.
you will need a 12 volt test light.
remove the negitive battery cable and connect one side of your test light to the battery negitive and the other side to the battery cable . and with the key off.. so now if you have a short some where the light should be lit. now what we have to do is start to pull fuses untill the light goes out. and when you find the fuse that is causing your short and drain your battery . then we have to look into the section of the wiring and components.
let me know what you find
later paul
Oct 18, 2008 | 2003 Ford Focus
50 people viewed this question
 Grubhead
Grubhead
