SOURCE: Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
SOURCE: No Power to My Toshiba TDP-S8
Thank you very much for the precise answer!
Had the same fault but repaired mine.
As I only had a 1000u/16V at hand, I put it in instead the swollen 3300u/10V. It works as well.
BTW this cap was extremely hard to desolder, as its holes are very tight in the PCB.
some addition, how to take it apart: the only screw at the center of the bottom is obviously needs to be taken out, then only the plastic holds it in one piece. I used two credit cards (well, not credit cards, but magnetic hotel keys, but looks the same) to insert between the upper and lower chassis to separate them. The capacitor in question was on the bottom board, which has the power connector.
SOURCE: HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
SOURCE: Toshiba TDP-SP1 Data Projector Pink Tint
go into menu and make sure input is computer and not rgb component. or just reset to factory defaults.
SOURCE: toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
