Sound problem with mitsubishi tv
I have a standard mitsubishi tv, the sound is staticy and broken yet it works fine when I play a dvd. I do have it connect to cable
    Problem Solver:
  • 8 Answers
Tuner or stereo decoder ic or cap in its decoder circuit, your dvd is sending audio through patch cords bypassing tuner - decoder audio circuit. advise just getting digital tuner from oboma and that will cure your problem.
Posted on Jul 08, 2009
I have a Mitsubishi WD-62525 TV with a Blue Ray DVD player hooked up to it. When I play a standard DVD, the picture is fine but if I play a Blue Ray DVD the picture is scrambled. I hooked the same DVD...
Might be tuned to the wrong output. The big tv has more than one input and is select able. Is there a blue ray selection for TV or input for that device.
Aug 09, 2014 | Mitsubishi WD Televison & Video
Speaker sounds very staticy
This is normally due to a bad connection, however it can also be caused by a blown speaker. replace with another speaker to see if the static is still there, if you still hear the static then the speaker is fine and the wire is broken somewhere, is the sound of static goes away then problem solved.
Apr 04, 2010 | 2003 Mitsubishi Eclipse Spyder
When I hook my dvd player up using the Component Video Input I get sound, but no video. Its not the dvd player because i hooked it up to my other tv and it worked fine. Thanks for any assistance
This might be the other TV's Video Input Cable Plug. Could be disconnected somewhere within, it may be disconnected. If your TV has two slots for Audio/Video Input, try using the other Slots maybe. :)
Apr 02, 2010 | Mitsubishi VS-60607 TV
Sunia LTD-1510 TV/DVD-problem w/ TV signal and sound
Do you have a schematic diagram of TV mine is broken as well
I have two of them
Tracy
tracyjeffords@sbcglobal.net
Mar 09, 2009 | Wanlida Group LTD-1510 15 in. TV/DVD Combo
No sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
Dec 09, 2008 | Televison & Video
Will play sound but no picture
1.check your video cable between DVD and TV.
2.in back of dvd one yellow socket only for video out others for some other purpose.
3.open tray conditon .-go to system menu on Remote -go to general set up page-video set up -and switch of .progressive -in OFF-mode.
then try it for video play back
4 if not ok replace the video decoder ic.
Nov 12, 2008 | Philips DVP642 DVD Player
Dvd plays fine sound/picture...No sound or picture with cable input
John,
To answer your question no, there are no fuses associated with the tuner input - through the "F" connector jack.
You have there a V26 chassis which has, among other things, standard digital and analog signal inputs. If one works but not the other - and you've verified it's not the cable then the only alternative is the signal board, Mitsubishi p/n# 930b923002...
But don't rush out and buy this puppy, it's a fairly expensive board and there are alternatives to replacing it new or used - PTS Electronics can rebuild this board for half the cost of a new one and most techs use PTS for that reason.
My best advice is to have a qualified shop estimate the repair and if they decide that the signal board needs to be replaced and quotes you a price ask them then about having it rebuilt.
Also take the unit to them to save the pickup/delivery charges and ask for your estimate in writing...
Hope this helps!
Bill
Dec 06, 2007 | Mitsubishi WD-52525 52" Rear Projection...
DVD player makes clicking sound but won't play
check for proper connectionor check for playing another dvd. as every things seem to be ok.
Sep 25, 2007 | Philips MWC13D6 TV
Strange audio problems
called a tve repair man tha is a buddy of minr hr had me unplug the tv to reset the ic ship and it worked !!! thanx and good luck
Jun 10, 2007 | RCA F27665 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
