GE 30 in. Profile JGP932 Gas Cooktop Logo
A
Anonymous Posted on Jan 08, 2014
How to GE JGP932 remove ignitor - GE 30 in. Profile JGP932 Gas Cooktop
1helpful
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Piezo igniter won't quit
Possible stuck burner switch or failed spark module. Unplug unit. Remove wires from burner switches at module and plug back in. If it starts sparking, replace module. If it stops, then replace switch harness.
Ge profile cook top snapping
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
My glass top has a broken in the corner on my jgp932 cooktop range can i just get the glass top replaced and can i do it myself
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
Will a 4 burner cooktop work on a ten gallon tank,or will I need a different regulator?
no.....check the unit if is low or high presure b4 u replace or buy a new regulator.....
1helpful
One igniter won't work right on my gas cooktop.
If you're not getting the ignitor sparking (you should hear it) when you turn the burner knob on for that burner, it could be that either the ignitor is dirty or caked with some gunk and needs to be cleaned.
The other issue could be that the ignitor is faulty and needs to be replaced. If you want to confirm a faulty ignitor before ordering a new one, you can swap it out with one of the other ignitors on the cook top. Be sure to unplug the cook top from the outlet thou, to prevent getting a shock, as those little sparkers can give you a pretty good jolt!
Just remove the grates and burners to get at the ignitor for cleaning it. To get at the ignitor, youll need to go under the cabinet or counter that the cooktop is installed on in order to remove the ignitor and swap it with one of the other ones. You'll see that these are held in place with a retaining clip you can remove with a flat bladed screwdriver, etc.
If you find that the one that isn't working is faulty, you can order one from your local appliance service store, or get one online. www.searspartsdirect.com lists parts for almost every appliance there is, just enter in the full model number to get a parts list, etc.
Hope you find this Very Helpful and best regards!
2answers
I have a GE JGP932 gas cooktop. All 4 igniters are
All four a supposedto spark....most ranges are like that. Check for, in order and only as far as you're comfortable:
1. Partially closed gas valves
2. Kinked/twisted flex connector
3. Blockage in tubing (grease buildup is pretty common - blowing through it often works)
4. Clogged inlet screen on regulator. N.B. Only do this if you're confident you can reassemble it safely as it must be done safely and correctly. If not taken apart carefully, you may warp/bend a key component. If not reaasembled correctly you could have a gas leak.
Good Luck.
5helpful
Ignition will not stop clicking...
Did you clean your stove recently? If the switches under the burner knobs get wet they will cause the burners to click. Unplug the unit or shut off the power for a day. Once the swithes dry, it should work normal.
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
